Hi All,
Maybe not a true blue transport issue, but just last few days, eldest son rang me with some backup generator problems.
Unit in question is an 8 kva powered by a Kohler single cylinder, horizontal crank, ohv engine.
Reported had been running ok, came back from a weekend away, started ok but after about 15 seconds, kept cutting out.
We took the fuel tank off, blew all the fuel lines out up as far as the carby, drained the fuel bowl
which looked clean.
Tried a brand new spark plug, still the same.
Had tried it with the air filter removed and did notice that when it does cut out after 15 odd seconds, get quite a backfire and like the engine is trying to "run on, as in pre ignition".
We run out of daylight, asked a few locals what they thought the
reason may be.
I would be thinking should only be fuel, havent completely removed the carby as yet, son getting a drivers manual tomorrow, OR spark.
One bloke suggested that seeing it is NOT the spark plug,(new one tried) there may be a breakdown in the coil/ magneto side of electrics, but if that was so, surely wouldnt keep starting even if running for short times??
I know very little about small engines, mine either work or they dont,
Anything to suggest??
Thanks, Dave_64
