Oxford Allen Scythe
1 year 2 weeks ago #254456 by grandad
Replied by grandad on topic Oxford Allen Scythe
          true
The following user(s) said Thank You: 180wannabe, Normanby, PaulFH
1 year 2 weeks ago #254457 by grandad
The following user(s) said Thank You: 180wannabe, Morris, PaulFH
1 year 2 weeks ago #254458 by grandad
          true
The following user(s) said Thank You: 180wannabe, wouldyou, Normanby, PaulFH, asw120, grumpy gumpy
1 year 2 weeks ago #254463 by cobbadog
Replied by cobbadog on topic Oxford Allen Scythe
This is where I am now. Gearbox been checked out, freed up the clutch due to lack of oil. Handles off and gearbox is now sealed up n clean.
Handles have been cleaned up. When removing them I had to remove the throttle cable as it runs inside a handle so tied some blind cord to it so to pull the cable back through on assembly.  But I broke the cord using the wire brush cup. So I ended up feeding some mig wire through. I have a broken tyne on the cutter bar but oliver1952 has kindly offered a replacement.
I bought the paint yesterday and is as close as possible to being mid Brunswick Green. It is Dulux Epoxy high gloss paint. Mew tubes are on the way n 2nd hand tyres are ready to fit once painted.
The following user(s) said Thank You: 180wannabe, Lang, PaulFH, asw120, oliver1950, grumpy gumpy
1 year 2 weeks ago #254465 by Zuffen
Replied by Zuffen on topic Oxford Allen Scythe
I used to watch the guys mow the grass (almost bush) every year, or so, at my Primary School in the 50's with these.
I always wanted to use one.
I see them on Marketplace quite often, but not silly enough to buy one.
I'm enjoying your efforts.
1 year 2 weeks ago #254469 by Mrsmackpaul
Replied by Mrsmackpaul on topic Oxford Allen Scythe
Well done Cobba, you'll be surprised, maybe not surprised at all
Just how well these cut, sickle mowers don't have to be super sharp and spotlessly clean to work well
The Allen Scythe mowers I remember with wide wheels and cutter bars were in really steep country and you mowed around the contour, if you tried to mow up and down the hill, on the way up the hill the mowers would over balance to much amd cutter bar is pointed towards the sky
Some blokes reckon they would flip right over, I think this might be stretching the truth a bit
But if mowing up and down steep hills, maybe keep this in mind
1 year 2 weeks ago #254471 by grandad
The following user(s) said Thank You: 180wannabe, cobbadog, Normanby, PaulFH
1 year 2 weeks ago #254472 by grandad
1 year 2 weeks ago #254474 by grandad
One problem I found was that the armature plate had been moving where it was attached to the crankcase, it was held in place by two screws.
First I cleaned up the faces
Then countersunk all the screw holes
1 year 2 weeks ago #254475 by grandad
First I found a bit of suitable tube and drilled it out to fit the screw
Then countersunk the screw holes
That way I figured the screws would only have to clamp the parts together without having to locate them as well
The following user(s) said Thank You: 180wannabe, cobbadog, Normanby, PaulFH, asw120, wee-allis, oliver1950
Time to create page: 0.435 seconds
