- Thank you received: 5907
Oxford Allen Scythe
1 year 5 months ago #254484
Replied by cobbadog on topic Oxford Allen Scythe
Perfect repair. It's rare those screws come loose n are normally a batch to undo.
1 year 5 months ago #254485
Not a lot stops them in their tracks, tough little buggers
1 year 5 months ago #254486
When mowing say embankments your suppose to mow across the slope. By engaging the ratchet drive only on the low side. This allows the free wheel to follow the driven nnis easier to handle. They are a heavy mower with so much cast iron in them n with both rachet drives engaged is hard to steer like having a LSD rear end.
About to post about the blades.
1 year 5 months ago #254487
Still cleaning parts ready for painting. Attacked the cutter bar this morning. Found I'm missing a pressure foot for the blade nhave that broken tyne. I removed the blade wire brushed it then touched it up with a file to remove some burrs underneath then a light touch up on the cutting edge. I knew that it cut grass already but while it's apart why not tidy it. Note the serrations on the side of the tyne to aid cutting. up.
1 year 5 months ago #254491
Replied by Lang on topic Oxford Allen Scythe
You may find this interesting.
1 year 5 months ago #254492
Thanks Lang, that's the one that helped me work out how the lid came off. Great clip to watch.
1 year 5 months ago #254594
The Allen Scythe has been sitting on the side while I build a garden shed. But yesterday some shrink wrap arrived for the throttle cable. The original outer covering was shredded but the wire outer cable n inner cable were fine n moved freely. So I ordered some 6mm shrink wrap with glue inside which can shrink down 3 times its OD.
This morning I put it on n I'm happy with the out come.
1 year 5 months ago #254605
by Zuffen
Replied by Zuffen on topic Oxford Allen Scythe
That came up really nicely. You should be very happy with that.
Are you letting your grass grow so you have a practice plot?
1 year 5 months ago #254608
by bel
Replied by bel on topic Oxford Allen Scythe
Hi I have got a spare cutter bar ( knife and fingers ) if it is of use to you / no cost
I live in Ballarat
I live in Ballarat
Time to create page: 0.338 seconds
