Oxford Allen Scythe
1 year 5 months ago #254620 by cobbadog
Replied by cobbadog on topic Oxford Allen Scythe
I will leave a plot to slash n show how it goes. Last time I ran it the grass just fell over n hid the bade but kept going. They are tough bastards to steer even with one wheel drive n 2 wheels are harder.
Thanks for the kind offer of a cutter bar n parts but distance is a bit of an issue.
Oliver1952 has kindly offered a tyne which is the most important part.
Picked up a load of sand n gravel, bags of cement so now to finish boarding up ready to drag out the mixer n get into it.
1 year 5 months ago #254740 by cobbadog
At last I'm back to the scythe. Just waiting for the garden shed to arrive but the 1500kgs have been mixed n laid by my little cement mixer.
so today I've stripped the ratchet drives off the wheels n decreased them now. New inner tubes arrived to Ho inside the better tyres plus 2 decals appropriate for the scythe have also arrived.
The following user(s) said Thank You: 180wannabe, eerfree, Morris, Mrsmackpaul, Normanby, PaulFH, asw120, oliver1950, grumpy gumpy
1 year 5 months ago #254771 by cobbadog
Due to light rain no spraying today so attacked the engine to try n date this toy. Usually date codes are on the flywheel but this 25C engine did not. Discovered that it is 1949/50.
Engine number is 740 46895 with spec 184B which is most likely the spark limiter to 2400 rpm.
The following user(s) said Thank You: 180wannabe, PaulFH, asw120, Zuffen, oliver1950
1 year 5 months ago #254774 by JOHN.K.
Replied by JOHN.K. on topic Oxford Allen Scythe
Restored one of these on FB for $400 coupla days ago.
1 year 5 months ago #254778 by cobbadog
For that price you should of bought it. Nothing eats long grass or crops like these things
1 year 4 months ago #254811 by cobbadog
While waiting for the replacement panels for the garden shed I decided to paint the cutter bar n fuel tank. Some models did this from production n I like it so here it is. Also I'm still cleaning the engine up but noticed jaw marks from a lathe or milling machine. Never noticed this before on a Villiers.
The following user(s) said Thank You: 180wannabe, PaulFH, oliver1950
1 year 4 months ago #254812 by Morris
Replied by Morris on topic Oxford Allen Scythe
Cobbadog,
I wonder if the jawmarks were made by a previous owner and not by the manufacturer?
The following user(s) said Thank You: 180wannabe, cobbadog, asw120
1 year 4 months ago #254817 by cobbadog
That is possible Morris as the crankcase has been split apart n silicone used on assembly.
In cleaning up more parts for the scythe I actually found a date, not on the flywheel but the cooling fins that bolt to the flywheel. Seems 11 / 51 is the date. Also in cleaning up the wheels you can see the remainder of the yellow paint used to highlight the lettering on the wheels.
1 year 4 months ago #254821 by grumpy gumpy
Replied by grumpy gumpy on topic Oxford Allen Scythe
With chuck marks like that, has it spun a bearing in the past and had the surfaces cleaned up, maybe has oversized bearing or bush fitted
Gumpy
1 year 4 months ago #254822 by JOHN.K.
Chuck marks are from Coventry chuck on a capstan or turret lathe .....very typical of UK manufacture in the 50s and 60s.......things you d think would be milled are turned on a turret lathe.
The following user(s) said Thank You: cobbadog, PaulFH, asw120
Time to create page: 0.322 seconds
