- Thank you received: 841
Ceres Hardi
1 year 1 month ago #255583
Replied by 180wannabe on topic Ceres Hardi
Random idea, does it work any better, or for longer, if you leave the lids off the tanks?
Brett.
Brett.
- Thank you received: 814
1 year 1 month ago #255585
by 77louie400
Replied by 77louie400 on topic Ceres Hardi
This is turning out like one of them murder mystery's, we are all on the edge of our seats trying to guess the outcome.
- Mrsmackpaul
- Thank you received: 8041
1 year 1 month ago #255587
Replied by Mrsmackpaul on topic Ceres Hardi
mammoth, nope it isn't slipping on the shaft
Gumpy, key ways all there and gripping
Brett no difference with lids on or off
Louie, it sure is
Im wondering if the pump mechanicals are worn
I wonder if what I assumed was a different stroke is a badly worn pump mechanicals ??
I'll split the casings and have a look
I doubt it is this but I dunno, it is strange how I can get it to run occasionally and run for a long time fine then it just slowly stops
Louie, it sure is
1 year 1 month ago #255588
by wee-allis
Replied by wee-allis on topic Ceres Hardi
Paul, I know this is a long shot, but I have had centrifugal pumps build up pressure ok, but when they get too much resistance, they start to create cavitation and lose pressure.
As I said, a long shot as I don't know if this same thing could happen with a diaphragm pump, not having had much to do with them.
Steve.
Steve.
- Thank you received: 122
1 year 1 month ago #255589
by Tired Iron
Replied by Tired Iron on topic Ceres Hardi
Hi Mrs
Another random idea. You're splitting the pump anyway
It's been sitting for a while? Maybe bits of hornet nest/rat/bird floating about inside & blocking ports intermittently?
You have all new suction hose I recall.
Sometimes chemicals can de-laminate hose. Been caught with that before
Good luck
Good luck
- Mrsmackpaul
1 year 1 month ago - 1 year 1 month ago #255591
Wee Steve
diaphragm pumps are positive displacement, what goes in must come out
a centrifical pump works the opposite
if a diaphragm pump is capped or blocked it either stalls or breaks, the more head diaphragm pump has the more power is needed to maintain revolutions
A centrifical pump, the higher the head the less power needed to maintain revolutions
Tired iron, the ports I believe are clean
So because it's only 40° I thought why not go out of the A.C. and have a look at the pump
I split my old pump apart, the original hardly used one I replaced with a bigger pump years ago and was some what surprised at it's inside
I am not us using this pump, it's a spare to compare what's what
The pump I'm using is in much better nic
Finding not a thing wrong I pulled it apart and then took some photos and put it back together
youtube.com/shorts/S4i-8L34fwk?si=yh37TpuYc2urvEUe
youtube.com/shorts/wXRcSf6OhmM?si=zaIJqxLKzbXQbZbu
the new diaphragms installed
The valves installed
Last edit: 1 year 1 month ago by Mrsmackpaul.
- Mrsmackpaul
1 year 1 month ago #255593
There's no sign of any movement on the shaft of the pulley moving
The head back on the pump, the regulator in agitate position
It pumps fine here in this position
The regulator in pump position
when in this position the red knob sets the pressure on the boom and the rest of the mix is bypassed thru agitation
this actually works but slowly the flow and pressure drop off
The pressure and flow drops off slowly when not on agitate
- Mrsmackpaul
1 year 1 month ago #255595
So I have a plan of attack
Ring hardi and see what they say, actually I have a pdf to down load and it talks about leaks in the suction side causing these issues
So if I pull the suction side of things out and somehow cap and seal it up to add air pressure to and maybe chuck it all in a stock trough and look for a leak ????
Even a squirty bottle (technical term I'm sure) with soapy water and add some of the Princesses dish washing liquid I might find the leak if it has one
These really are a crap design, so many joins and places to leak on the suction side
Two joins inside the tank, two more on the tank on the outside, then 6 actually on tyhe pump head
Then and in hoses and a PVC pipe and things just get harder and harder
1 year 1 month ago #255597
Paul, did you end up measuring the actual operating speed of the pump?
The diaphragm pump on my tray mount sprayer says 550 RPM max.
I am wondering if the pump is maybe spinning a bit too quickly, whether the valves are keeping up, and you are maybe loosing suction and then pressure, because of that???
Or because of the very short stroke of the diaphragms, whether excess speed would cause the chem mix to froth up inside the pump as it passes through, and therefore not pump as well???
Probably all unlikely, but i am afraid i am quickly running out of suggestions!
Brett.
Brett.
- Mrsmackpaul
1 year 1 month ago - 1 year 1 month ago #255599
No Brett not yet, according to the pump it can run at 800 rpm
I have no measuring device that I know of in my tools
With a 2 inch pulley on the motor and a 4 inch on the pump the motor would have to be spinning at 1600 rpm before I am to quick
Having said that, I can't really tell how quick it's spinning, the motor is at idle
And I am wondering about whether the valves get sort of bound up
As in if it can't get rid of the liquid then it can't let more in, I don't see how this can happen but I dunno, it could
I guess I need to make sure there is no leak letting air in, I wonder if the fluid slows then maybe as it's running past it sort works like a venturie type of deal and somehow sucks air in, but I really don't know
Time to create page: 0.333 seconds
