- Thank you received: 8051
Ceres Hardi
- Mrsmackpaul
- Away
1 year 1 month ago #255665
Replied by Mrsmackpaul on topic Ceres Hardi
Steve, this is probably true
One of my good tradesman used to make me work out what was wrong with a lift without touching anything
Just by observation
Actually both those good tradesman were like that
Just by observation
- Mrsmackpaul
- Away
1 year 1 month ago #255668
1 year 1 month ago #255703
Replied by mammoth on topic Ceres Hardi
Hardi seem to use terrible plastics, not just that red stuff but for internal valves etc as well. Often just crumbles in your hand. In the end I gave up on my efforts and hired a contractor with a sat nav and who somehow always did the job at the right time and got a good kill.
- Mrsmackpaul
- Away
8 months 5 days ago #258195
Gunna start spraying stuff again and thought I best treat the Ceres to a fresh set of treads
So got the most aggressive tread and a bit more like the 6.50 x 14 donuts it began with
So order the fresh treads and they arrive, fired up the Ceres and start to toodle down to the tyre service
I thought bugger me, she revs but shebno move very much, so toodle along in 3rd and very light on the go pedal and made it down to the tyre service
Limp back home with it's fresh treads, then straight back to town to order a fresh clutch kit
while I wait for this fresh clutch kit to arrive I decided I best yank the clutch, I was pretty sure it was only a bit stuck on the spline or throw out bearing was sticking.
So tonight I decide to yank the box
So very simple to work on these little jobs
Had the box off and on the deck in a hour amd a half, much quicker than the Mack or splitting a tractor
- Mrsmackpaul
- Away
8 months 5 days ago #258196
Clutch wasn't completely stuffed, but also wasn't real good either, I think the throw out bearing was binding a bit on dried up grease
It is always comical when working on cars and things that size at just how small everything is
I also noted when that when I spoke about the Ceres C - er - s
I learnt it is more like Cer - hey, almost French like
Sounds much more classy
The following user(s) said Thank You: 180wannabe, cobbadog, eerfree, Normanby, 77louie400, PaulFH, asw120, roKWiz, wee-allis, oliver1950
- Mrsmackpaul
- Away
8 months 1 hour ago #258259
New clutch arrived and is now installed and the gear box bolted back in
The new clutch is purple and has a extreme sticker on it, so I'm sure that will help contain the unbridled horses of the little 2.4 litre power house
These really are a value packed little unit
The following user(s) said Thank You: bparo, 180wannabe, cobbadog, eerfree, ianoz, Normanby, PaulFH, asw120, wee-allis
- Mrsmackpaul
- Away
7 months 3 weeks ago #258292
Well it all back together okay
No parts left over, I ordered a new slave cylinder for the clutch but thouvht Im in a hurry and its working fine so I'll keep it as a spare
Filled the tank and got to the paddock and stopped to open the gate, wouldn't you know it, I couldn't get it back into gear
So the new slave cylinder went in
The spray tank works fantastic
The Kia needa some brake work, but it pulls a bit this way and that under heavy breaking
- Mrsmackpaul
- Away
7 months 3 weeks ago #258293
The following user(s) said Thank You: 180wannabe, cobbadog, PaulFH, asw120, Fighting Rust, PDU, oliver1950
7 months 3 weeks ago #258294
by V8Ian
Replied by V8Ian on topic Ceres Hardi
"The Kia needa some brake work, but it pulls a bit this way and that under heavy breaking "
Easy fix Paul, don't brake heavy.
7 months 3 weeks ago #258296
by wee-allis
Replied by wee-allis on topic Ceres Hardi
All the work has been worth the effort. Well done Mrs.
Time to create page: 0.384 seconds
