Leak down test
6 months 5 days ago #258859 by cobbadog
Leak down test was created by cobbadog
Is there a basic way to do a leak down test. The David Brown is not running on all 4 cylinders so before removing the head I thought of doing a leak down test.
I have a compression tester, plus will be redoing all the basics like plugs, leads n timing just in case but deep down I feel I have a sticky valve or 2.
6 months 5 days ago - 6 months 5 days ago #258862 by jon_d
Replied by jon_d on topic Leak down test
Cobba,
The cylinder in question has to be BDC and valves closed.
Fill it with compressed air, measuring the pressure. Then shut of the compressed air feed and monitor the leakage.
This is a leak down tester I made for RV gas systems. It can give some ideas.
The regulator is to set the system pressure to 2.75kpa.
In your case, the coupling would screw into the head and no regulator would be needed.
I connect the hose to the system. Pressurize via the schroder valve. Shut off the left tap.  Read the pressure. The regulator correctly sets the system pressure.  Over time, the gauge set at say 10psi should not drop.
Note: the right hand tap is  used to check the test system for leakage. eg. Close and pressurize. There should be no leakage shown on the gauge. When testing the system, the right hand tap remains open.
Last edit: 6 months 5 days ago by jon_d.
The following user(s) said Thank You: 180wannabe, cobbadog, PaulFH
6 months 5 days ago #258863 by cobbadog
Replied by cobbadog on topic Leak down test
Thanks for that. For some odd reason every video clips I've watched say piston at TDC.
6 months 5 days ago #258866 by asw120
Replied by asw120 on topic Leak down test
The valves are only closed at TDC. I guess you could back the rockers right off to get them closed at BDC.
6 months 5 days ago #258867 by JOHN.K.
Replied by JOHN.K. on topic Leak down test
You used to get a manifold vacuum tester that would indicate if valves were leaking,late ignition,bad plugs or whatever.
The following user(s) said Thank You: 180wannabe, cobbadog, PaulFH, asw120, wee-allis
6 months 5 days ago #258869 by wee-allis
Replied by wee-allis on topic Leak down test
Cobba, a quick easy test is to have the piston at TDC, make an adapter to fit the plug hole, apply compressed air and listen to the inlet and exhaust for a leak.
It's a very basic and simple test but it will give you an idea.
6 months 5 days ago #258870 by jon_d
 I was thinking that when at TDC, the pressure can push the piston down and it'll lose pressure.
At BDC, yes, the rockers will need to be loosened.
A compression test might give you the answers more easily. Just remember to have the throttle wide open.
6 months 4 days ago #258872 by wee-allis
Not if you put it in gear.
6 months 4 days ago #258877 by cobbadog
I do have a vacuum gauge but don't understand how it can pon point the trouble
6 months 4 days ago - 6 months 4 days ago #258879 by Fighting Rust
Last edit: 6 months 4 days ago by Fighting Rust.
The following user(s) said Thank You: cobbadog, PaulFH, asw120, wee-allis
Time to create page: 0.309 seconds
