Leak down test
4 months 3 weeks ago #260435 by jon_d
Replied by jon_d on topic Leak down test
Yes, hope Dee is ok too.
The oil  pressure is running on the bypass. Is the pressure sender before or after the filter?
Wait till it gets up to full temp and the idle pressure should drop.
With photo #2, I thought you'd cut a hole in the roof for the exhuast.   Took a bit to work out that it wasn't a hole.
4 months 3 weeks ago #260436 by cobbadog
Replied by cobbadog on topic Leak down test
Sender is plumbed into the block before the filter. IT has never dropped from this reading unless i shut him down.
As for Dee, we will know more hopefully tomorrow afternoon. While waiting for that I have my annual cut n freeze session at the skin cance clinic for the annual cut n paste.
The following user(s) said Thank You: Mrsmackpaul, PaulFH, asw120, wee-allis
4 months 3 weeks ago #260437 by mammoth
Replied by mammoth on topic Leak down test
As the oil is going via the bypass little if any is getting filtered so you need to reverse whatever you did prior to the rebuild.
4 months 3 weeks ago #260443 by Morris
Replied by Morris on topic Leak down test
Cobbadog, I wish you and Cobbarette all the best. Please pass on my love to Dee. She might remember when you came down to see me and our collection. It's about time you both called in again. The place has improved a bit.
Morris.
4 months 3 weeks ago - 4 months 3 weeks ago #260447 by jon_d
This is then just measuring the oil pressure release valve setting.   It's not measuring the oil pressure in the oil gallery which is where the oil pressure drops off as the oil drains past the bearings.
The sender should to be plumbed into the gallery after the oil filter.
It's possible that the pump is high volume and is capable of maintaining 40psi  in the galleries at idle and high revs.  But generally, one expects to see a fluctuating gauge as revs vary.
Last edit: 4 months 3 weeks ago by jon_d.
4 months 3 weeks ago #260448 by cobbadog
Where it's connected us the one n only place for oil pressure gauge to be fitted, there are no other options so can't see how it's wrong
4 months 2 weeks ago #260458 by Zuffen
Replied by Zuffen on topic Leak down test
I'm with jon_d.
I'd like to find a way to have the sender after the filter.
Too suspicious have 40psi at idle on any Pommy engine.
4 months 2 weeks ago #260461 by cobbadog
to change it to anywhere else you would have to guess where the galleries are. Its dsetup as per the manual from DB. As I said I lifted te pressure when there was a bearing issue with them badly worn.
4 months 2 weeks ago #260462 by Lang
Replied by Lang on topic Leak down test
Seems to be common sense to have pressure after the oil filter (if it is full flow. If just bypass makes no difference
I suppose you have this manual with no specific answer other than relief valve set to 40psi.
  bundybearsshed.com.au/wp-content/uploads...Book-DBT301-1953.pdf
4 months 2 weeks ago #260477 by Zuffen
It's not a problem if you KNOW the filter isn't blocked or even partially blocked.
Time to create page: 0.263 seconds
