- Thank you received: 1566
Tube to tubeless conversion acco 1730B
- Tom
5 years 6 months ago #208896
by Tom
Tube to tubeless conversion acco 1730B was created by Tom
Hi all,
I currently have a 1978 acco 1730b with 9.00r20 (7"wide rim) tube spider demountable rims, I am wanting to change to 11r22.5 tubeless. And I need some advise.
I have test fitted a 11r22.5 worn out tyre with a 8.25"rim on the front axle, at full right hand lock it clears the drag link by about 10-15mm. Will this be enough or will I need an reverse offset rim? Am I better of sticking with the 9.00's.( the front axle is a 6 spoke spider)
Regarding the rear axle it is an eaton no4 two speed. I haven't test fit a set off 11r22.5 tyres but it looks like I might run out of room or be very close fit between the chassis/leaf spring and the side wall of the tyre.
The main reason for the change is to get rid of the tubes, as I had to do a puncture repair due to a piece of rust flake on the sidewall, and it is something that I would like to avoid in the future. Also the 11r22.5's seem a little cheaper, as I am looking to replace the full set of drives and steers.
I have searched the internet and have seen similar truck withe the 11r22.5, I'm just not sure if special offset rims are used. And I want to make sure it will all work before I start spending money. Thanks
Thanks
Thanks
5 years 6 months ago #208898
by Gryphon
Replied by Gryphon on topic Tube to tubeless conversion acco 1730B
Please remember any replies need to be manual approved by a moderator before they will appear on your page....Terry
5 years 6 months ago #208900
Replied by Swishy on topic Tube to tubeless conversion acco 1730B
Tom
gudday m8
RE: I have test fitted a 11r22.5 worn out tyre with a 8.25"rim on the front axle,
Take th@ tyre n rim n put on the drive rear axle n see how much clearance U got fromt the spring pak
U may have to turn the bolts around on the flat 'U' bolt doodadd that keeps the sprink pak in lign ..... or cut the emd of thread off so it dun fowl the tyre
RE: at full right hand lock it clears the drag link by about 10-15mm.
Any clearance is better than no clearance @ all ... wen on full lock U wont B doin 100 but probly walkin speed
If U can get them to fit try usein common garden variety tubless rims as off set rims will cost more and may not suitable for all round the complete truck
gudday m8
- Thank you received: 7600
5 years 6 months ago #208934
Replied by Mrsmackpaul on topic Tube to tubeless conversion acco 1730B
Im pretty sure Swishman is onto it
I believe standard tubeless rims will be fine
5 years 6 months ago #208948
Replied by JOHN.K. on topic Tube to tubeless conversion acco 1730B
Be careful ,even a shiny patch on the drag link is a defect and big fine ,so make sure a bit of tyre runout wont touch it.
Time to create page: 0.284 seconds
