- Thank you received: 841
PBR Air–Over–Hydraulic Brake System model CA300 help please
- Dolphin
4 years 8 months ago #222231
by Dolphin
PBR Air–Over–Hydraulic Brake System model CA300 help please was created by Dolphin
Hi needing some help please with CA300 brake system. Trying to workout why the low air pressure light wont go off unless you pull the park brake lever down. Have put new sensor in and still doing the samething. It is hooked up to the trailer brakes for some reason and not sure if this correct or not ? any help would be great thanks
P.S its on an International D1950
4 years 8 months ago #222239
Replied by 180wannabe on topic PBR Air–Over–Hydraulic Brake System model CA300 help please
I'm wondering if it has had a low air warning switch fitted in place of the stop light switch? If so, the light will be on until the hand controlled is pulled down.
The low air switch should be at, or in the feed line from the air reservoir. There should be a brake light (brakes on) switch in the control line to the trailer.
Maybe just make sure/test that the right type of switch is fitted, i think the low air switch would be a normally closed switch, and the brake light switch would be a normally open switch.
4 years 8 months ago #222242
Replied by hayseed on topic PBR Air–Over–Hydraulic Brake System model CA300 help please
Dolphin, Do a search on here for CA300 there is several threads about them..
Time to create page: 0.248 seconds
