International AB130
11 years 8 months ago #124179
by carmoda
International AB130 All Wheel Drive caretaker
Replied by carmoda on topic Re: International AB130
Fantastic Info Roger! My local mechanic thinks he has some old Inter parts lying around might be worth a look... I'll also give prices a call. ASW anything you can spare for me to use as either a template of modify.?
I am also missing a spare wheel and quite a few wheel nuts. any pointers appreciated..
11 years 8 months ago #124180
Replied by asw120 on topic Re: International AB130
Carmoda, I reckon I would have a spare wheel with lock ring.
Free, but you gotta keep a lookout for a 7.50-type or a hubcap. Or a 110 diff? We could work something out.
I should have some wheel nuts...?
I probably (fairly sure) have a spare 2wd handbrake band (I need to keep 1 'cause I want to assemble an AB110 from bits I have) I might be able to make up a set of all the actuating gear. You will have to help me look, but it's all in one place.(a D1210 van chock full) I wrecked an AA120 4x4, but wasn't all there. Maybe a handbrake linkage? If not, I'm sure I could find a 2wd one which would be easy to lengthen.
Could use my spare 4wd band as a template no worries.
I'm near Ipswich (Chuwar). Probably best you PM me and we can sort something out if nothing easier turns up.
ASW. (Jarrod)
ASW. (Jarrod)
11 years 8 months ago #124181
Replied by bigcam on topic Re: International AB130
Hi Mate, pretty sure the wheels were still on the one at Prices, I reckon they would have the handbrake assembly as well.
ASW, those diffs and wheels are a lot bigger than a 110.
Had to get some electrical stuff this morning and this C 1300 was parked in a painters yard in Salisbury, just had the Dulux reco, had a Perkins in it.
11 years 8 months ago #124182
That's nice! There's one like it with duals on the back near me.
Yep, I know about the wheels. I have plenty of 110 wheels, but I'm always looking for 7.00-7.50 type 6-stud singles.
Notice the wide lockrings on the one in your picture; they're the 8.25-9.00 type which I'm pretty sure carmoda has. I have a couple(?) of those I don't need.
Of all the stuff I wrecked out over the years, I think I have enough parts to assemble an AB110. I gave away my last 110 diff, however and don't really want to use the 8-stud gear from under the 1210 van.
It's a "one day" project. If I thought long enough, I could probably come up with a page of stuff I don't have, but I have most of it.
ASW.
ASW.
11 years 8 months ago #124183
Replied by on topic Re: International AB130
11 years 8 months ago #124184
by carmoda
Wow. This has to be up there with the the other worlds most helpful forums.
ASW - definitely take you up on that. I'm just down the road (Peak Crossing).
JBlair, Awesome schematic. I'll print that out. Thank you so much!
11 years 8 months ago #124185
by rb057
AB120 4x4
Replied by rb057 on topic Re: International AB130
Hi carmoda,
No worries and glad to help.
ASW, on the rims with the larger lock rings, did the rims have a matching larger flange also?
Regards
Roger
Regards
Roger
AB120 4x4
11 years 8 months ago #124186
Yes.
ASW.
Yes.
ASW.
11 years 8 months ago #124187
by carmoda
anyone know where i can get a small section of my fuel line repaired? it's a small rubber (with brass ends) section 12cms long just before the filter. Rubbers gone brittle.
11 years 8 months ago #124188
by indianman
Replied by indianman on topic Re: International AB130
G'day Carmoda if it has got the crimped ends on it then you can carefully cut around the crimp and remove it and you should have a fitting with a small barb just replace the hose with some quality fuel line and hose clamp on.
Jon
Jon
Time to create page: 0.264 seconds
