International AB130
11 years 4 months ago #124189 by asw120
Replied by asw120 on topic Re: International AB130
Hi carmoda, was good to catch up the other day.
What indianman said is right. We started on that subject, but kept getting sidetracked.
You will also find one of those hoses on top of the fuel tank. Do it as well, even if it's still good. It will fail soon enough and likely with intermittent problems at first. You can do without that trouble.
ASW.
11 years 4 months ago #124190 by asw120
Carmoda, I found the handbrake cams and pins - we were only inches away! They were in the old Commodore. Still have to find the big J-bolt and springs, though. I'll keep looking.
ASW.
11 years 4 months ago #124191 by rb057
Replied by rb057 on topic Re: International AB130
HI Carmoda,
Did you end up getting your fuel hoses sorted?
Agree with the others, in the past I have carefully removed the old hose from the crimp fittings and then used new hose with suitable hose clamps.
When checking through the parts that came with our ute found these two in the bottom of the box,
NOS tank to fuel line and fuel line to fuel pump hoses.
If you are having toruble sourcing hoses in Boonah and are wanting "fitted" hoses, I can take these as samples into a Hydraulics shop in Brisbane (where my brother works) and have a pair made up, correct hose and fittings.
I note that the hoses on our ute are stainless braided lines that appear to be original.
Regards
Roger
AB120 4x4
11 years 1 month ago #124192 by carmoda
Replied by carmoda on topic Re: International AB130
Well finally my shed is finished.... so over the Christmas/NY break I have been slowly moving my tools in. Once in I'll start to strip down the cabin or quick respray and give the engine some TLC.
One Problem....this turned up.
It might delay the proceedings.
a pic of the new shed..
International AB130 All Wheel Drive caretaker
11 years 1 month ago #124193 by Bugly
Replied by Bugly on topic Re: International AB130
Jeez carmoda ... that's a nice 'man cave'!! Fit lotsa goodies in that one!! [smiley=thumbsup.gif] [smiley=thumbsup.gif]
11 years 1 month ago #124194 by carmoda
rb057, i got my top rubber fuel hose section rebuilt by the kind fellas at Pirtek (Hemmant) cost about $20. The existing bottom one seems fine... its really supple and clean so i might leave it. I just need to get the old girl running under her own steam so I can move her into the shed to clean up that cabin for a respray. I know she runs as the fella i purchased her from drove her onto the trailer. The brakes are the only serious mechanical problem.
11 years 1 month ago #124195 by carmoda
if anyone has a schematic of the electrical system for the AB series or similar i'd be very grateful. I keep an eye out on eBay for any manuals etc. I am happy to pay for postage both ways if need be. I have a very fancy scanner at work.
11 years 1 month ago #124196 by rb057
Hi Anthony,
The shed looks good.
Here's a small size copy of the electrical diagram, from two diffrent sources and links to high resolution images (all for educational purposes).
i1278.photobucket.com/albums/y513/rb057/...0292_zps405de453.jpg
i1278.photobucket.com/albums/y513/rb057/...0295_zpsb34f24e1.jpg
Might have take our ute for a drive out your way and call in with our manuals. (will PM with contact details)
Regards
Roger
AB120 4x4
11 years 1 month ago #124197 by carmoda
OK, so i have a handle on what wires are what that thanks to Roger... Now to get the old girl to turn over so i can drive her into the shed to do some real work. My problem is she isn't drawing up fuel from the tank. The engine kicks over fine and I know she runs as we drove her on the trailer when i picked her up. that was via hooking up a fuel container directly to the pump (because of the ruptured line, now repaired). So the pump works... i guess I'll need to prime the pump. any tips? here a a pic of the pump and the new section of hose.
11 years 1 month ago #124198 by bigcam
Replied by bigcam on topic Re: International AB130
Looks like your fuel pump is full of crap just looking at the glass bowl.
Time to create page: 0.444 seconds
