Diamond T steering box
11 years 11 months ago #132818
by To a T
Diamond T steering box was created by To a T
Giddday, After my leads for a replacement Ross steering box all fell through I bit the bullet and took it to a recommended engineer shop. I should of done this in the first place.
It needed the sector shaft straightening, machining and rechrome and new bushes and seals. All these parts were common parts and readily available(and only a 2 week turnaround).
The question now is what lubricant do I use. Originally it had what looks like a grease/oil mixture. It had the consistency of yoghurt.
Do I need to mix this or do I use a light grease?
Any help would be appreciated. Thanks
David
David
11 years 11 months ago #132819
by melonreo
Replied by melonreo on topic Re: Diamond T steering box
I mixed gear oil and grease and made up a wonderfull brew ,
then I found it on a spec sheet
CALTEX
THUBAN GEAR
OIL EP
sae 85w-140
extreme pressure gear oil plenty out there and cheap , there is a bunge up the top on the side , fill er up to there
CALTEX
THUBAN GEAR
OIL EP
sae 85w-140
11 years 11 months ago #132821
Replied by asw120 on topic Re: Diamond T steering box
You can still get self-levelling grease from BP, I use it in the little Ross boxes in the Studes. Seems to work alright, although it seems a little light.
You can also buy very heavy worm gear oil. We use up to 600W at work in old lift gearboxes.
ASW.
ASW.
11 years 11 months ago #132822
by AT4114
Replied by AT4114 on topic Re: Diamond T steering box
Hey TO a T were did you find the parts for your ross steering box or did the machine shop make them for you regard Bryant
11 years 11 months ago #132823
by To a T
Replied by To a T on topic Re: Diamond T steering box
Thanks fellas. Will get down and dirty over chrissy break(too busy at the min-you all should relate).
ASW the bearings and races were still good so the shop found out after measuring that bushes and seal were standard stock off the shelf items.
Anyone know of anyone in or around Sydney who make up drag links.
David
David
11 years 11 months ago #132824
Try either; www.hydrosteer.com.au/
or; www.allpowersteering.com.au/
They'll make one up for, & they would both have agents/stockists in Sydney.
Replied by hayseed on topic Re: Diamond T steering box
David
11 years 11 months ago #132825
by treeepirate
Replied by treeepirate on topic Re: Diamond T steering box
Re Ross s/box
Hard-chrome is porous so picks up the oil, depending on the bush material either sintered (porous) the other one I can not remember phosphor bronze I think will be grooved to allow oil to get to the bearing surface,
main thing no grease, or moly,
EP Gear oil,
no grooves in the bush thinest oil you can find, (there are thin gear oils made these days)
cheers
EP Gear oil,
cheers
Time to create page: 0.261 seconds
