rust removal
11 years 2 weeks ago - 11 years 2 weeks ago #135330 by hypermung
Replied by hypermung on topic Re: rust removal
Hey Fellas... We're hijacking Geoff's thread on ELECTROLYTIC rust removal, but it could be for the better.. The molasses method works much better on really bad rust, & is a whole lot safer... Remember, water & electricity don't mix...!
Last edit: 11 years 2 weeks ago by hypermung.
11 years 2 weeks ago #135331 by
Replied by on topic Re: rust removal
I use citric acid to remove rust, on the shelf at the supermarket and cheap, Like me! Got the idea from old mate over on the west coast, thanks OneTrack. The molassis would be better with large items in big drums. How much is a couple of litres in bulk? Cheers Ross
southbound nothing wrong with that but the concetration you get it in is nothing (id drink that useless crap) you need proofed concentrate (phosphorus in chemist 1200 proof strength)
caution using it as it will dissolve your hand in 5 minutes :)
11 years 2 weeks ago #135332 by hypermung
Even vinegar will work if you leave it in there long enough... It's only an acid after all ! Same as the old one about putting metal in Cola.. it's all Acidic ! So imagine what Cola does to your guts :o...
Imagine also what breathing the fumes from 1200 proof phosphoric acid would do to your lungs... :'(
Now we ARE getting REALLY dangerous...
Molasses is much safer, bio-degradable & won't eat your hand off in 5 minutes if it accidently splashes onto you + you can also make it into some bitchin moonshine ;D
11 years 2 weeks ago #135333 by austink8
Replied by austink8 on topic Re: rust removal
I have been hijacked and yes for the better after 4or5 days trying with electrolysis and at best a 70% success all the really hard bits were left lve moved to molasses the rims just fit into a plastic 205 lt drum I chopped the top off so I will do most of the rims at once and just learn some patience. a friend told me that it is very harsh on cast material so I have to keep a close eye on it thanks all
11 years 2 weeks ago #135334 by asw120
Replied by asw120 on topic Re: rust removal
Just be careful, if they are riveted rims, pull them out every day to check the rivets. If they are welded, go for broke!
ASW.
11 years 2 weeks ago #135335 by Swishy
Replied by Swishy on topic Re: rust removal
Dunno how good thiz iz
me knokd up this flyer 10 years ago
it haz bin used on the left coast on Mammoths potts me thinx
11 years 2 weeks ago #135336 by hypermung
[IMG
11 years 2 weeks ago - 11 years 2 weeks ago #135337 by
Thanks for that hyper. On topic try breathe 1200 proof phosphourous = see you in,life support bra
but what takes u guys days and weeks takes minutes and hours plus i can realease a coating agent so i can store pieces in prime condition
sorry for the mistakes im on a phone doohickey
11 years 2 weeks ago #135338 by bigcam
Replied by bigcam on topic Re: rust removal
Swishy, which lead does the Magna welding rod go on?
The Anode or the cathode?
Maybe that is why Mammoth's block has taken so long?
Might have had the polarity wrong.
11 years 2 weeks ago - 11 years 2 weeks ago #135339 by hypermung
Ok then... Seeing's how we've successfully hijacked this most excellent thread, I thought I'd fire one more volley for the molasses Army. ;D I have a couple of headlight buckets in 'The Tank' now.. This is the 'Tank' (25L bucket with lid)
[IMG
These are the headlight buckets I put in a few days ago... (less reflectors of course)
[IMG
Now, with all this good Vs bad rust removal talk happening today, I decided to go & have a look @ how they were going
[IMG
[IMG
[IMG
[IMG
Now.... This is after only 3 days in 'The Tank'... No sanding, no grinding, no wire brushing... No effort on my behalf except for wiring them up, putting them into the tank & waiting. Can anyone see shiny metal?
Is this where I say "I rest my case"?
;D
