1963 Austin Metro Van FG K60
First challenge is getting the rear brake drum off, it looks as though I need to remove the half axle and then the drum, is this so, are there any traps?
Appreciate any advice offered.
Alex
Thanks again.
Alex
The bearings should be set so that there is "only a perceptible amount of end play".
Bottom line is that I am comfortable to take it apart now and will do so to make sure all is well under the drum. The truck has been in a museum and it appears the hand brake has been on for 6 years.
Many thanks for your help, I appreciate it.
Alex
Zackly the same as an English 'D-Series' Ford.I don't have a manual for them, and it sounds quite odd. As the BMC trucks carry the genome of pre war Morris and Austins I had a look at a 1930's Morris Commercial 3 tonner. It seems that the brake drum and the hub are the one item, and as you say, to remove the brake drum you have to follow what would be the procedure for removing a hub in a more conventional truck. That is remove the half shaft, then the bearing retaining nut and tab washer etc.
Alex
Alex
www.flickr.com/photos/46046969@N03/13259635284/in/photostream/
Seen last week at Fielding
