- Thank you received: 300
1938 Fargo Pickup.
3 years 5 months ago #216598
by someguy
Replied by someguy on topic 1938 Fargo Pickup.
Great reference photos, thanks Lang. I appreciate you acknowledging the incorrect hardware, LOL.
That marble reflector is very nice as well.
3 years 4 months ago #217393
by someguy
While waiting for my wiring to arrive I figured I would deal with some of the sheet metal problem the Fargo has.
I removed all the fenders (one at a time) and cleaned up all the hardware and welded up various cracks and tears,
and managed to push a few dents and bruises while they were off.
I was amazed what just a good cleaning will do.
3 years 4 months ago #217394
by someguy
When I removed the front bumper to remedy some bad hardware choices over the years.
I noticed there was a mangled piece of sheetmetal between the body gasket and the bumper bolt.
There was only one on the drivers side. I got it off and realized it was a garnish that covers the
area where the bumper is attached to the frame.
The rubber gaskets were in quite bad condition but I trimmed the ratty outer part of the rubber off
and buffed them smooth. they are totally acceptable now.
3 years 4 months ago #217395
by someguy
Seeing as I only had one of the bumper garnishes, I had to make a second one.
I just used two sockets of closely appropriate size on each side of the piece of sheetmetal
and pressed the dimple in with a 6" vice and a small amount of sniping on the vice handle.
3 years 4 months ago #217396
Replied by asw120 on topic 1938 Fargo Pickup.
Love the straight-forward thinking on how to make that garnish.
The repair on the mudguard / fender is also particularly nice.
Great stuff.
Great stuff.
- Thank you received: 4707
3 years 4 months ago #217403
Replied by Mrsmackpaul on topic 1938 Fargo Pickup.
Fantastic stuff, thanks for sharing
3 years 3 months ago #217418
Replied by cobbadog on topic 1938 Fargo Pickup.
Lovely work on the repairs and duplication of the garnishing cover bracket well done. I have a similar job but a bit bigger comming up soon, the mower deck on the ride on mower. I too will be made in pieces as you have done.
You are making great progress on your restoration.
The following user(s) said Thank You: someguy
3 years 3 months ago - 3 years 3 months ago #217421
by someguy
Now that the fenders are nice and solid and 65% rattle free (probably the best I could hope for).
It's time to move on to the wiring. I laid out the harness and labelled everything.
I managed to find all the proper Chrysler wiring for it and ordered all the different gauges and colours.
The truck only came with one tail light and no signals so I added the necessary wiring to accommodate
a second tail light and signal lights.
The steering wheel of my car literally has more wiring than the entire truck. so It shouldn't be too difficult
to replicate the harness at a fraction of what a pre made harness would cost.
The wiring supplier (Harnesses Unlimited) in the US, had all of the correct connectors and terminals needed.
While removing the old tail light wiring, I noticed in the loom that covers the wiring back to the tail light had
this cool little hoop woven into it for what I assume aided pulling the wiring in through the chassis.
Last edit: 3 years 3 months ago by someguy.
Time to create page: 0.636 seconds
