- Thank you received: 675
costs of DIY engine rebuild?
11 years 8 months ago #138812
Replied by jon_d on topic Re: costs of DIY engine rebuild?
And I have the 214, 300 petrol engine manual so can scan stuff and post it here as you go.
11 years 8 months ago #138813
by harpo
d.l.marks&&( harpo)&& on&&LA SNAIL -(69 beddie)&&&
Replied by harpo on topic Re: costs of DIY engine rebuild?
Hi,
had a seized engine in an old grey fergie. Was told to pour boiling water into the block several times. I did this and along with the wd40 down the plug holes I got the old girl to turn over and eventually run. It appears that the boiling water expands the block from the pistons, anyway good luck.
11 years 8 months ago #138814
Replied by Sarge on topic Re: costs of DIY engine rebuild?
Beddy, the experts are telling ya the way to play...
get some spanners out and have a crack, and I reckon you could get another whole truck for about $500 with a running motor.... if you stuff this one.
Here is Beddy's truck....
/me
/me
- beddyfarmtruck
11 years 8 months ago #138815
by beddyfarmtruck
Replied by beddyfarmtruck on topic Re: costs of DIY engine rebuild?
not entirely sure why it was stuck but it freed up when moving it from the paddock to the shed, something to do with the gears as Dad was selecting different gears while my brother was pulling the truck with the tractor to get it rolling, we had the rocker cover off at the time as we had been inspecting it before dad decided to move the truck, anyway the truck started rolling then there was a small clunk and then the rockers started moving it turns freely now.
it needs some new seals and such but with the new carby and a new battery the 300 should start
11 years 8 months ago - 11 years 8 months ago #138816
by oldgmc
Replied by oldgmc on topic Re: costs of DIY engine rebuild?
Good luck Beddy is that a Ford sitting next to it like to see a piccy
Last edit: 11 years 8 months ago by oldgmc.
11 years 8 months ago #138817
by Bugly
Replied by Bugly on topic Re: costs of DIY engine rebuild?
There's good clunks and bad clunks, hope this was a good clunk!!... anyway the truck started rolling then there was a small clunk and then the rockers started moving it turns freely now.
- beddyfarmtruck
11 years 8 months ago #138818
by beddyfarmtruck
seems to have been a good clunk it's moving, just need to fix the electricals
11 years 8 months ago #138819
by ray
Replied by ray on topic Re: costs of DIY engine rebuild?
Might have just been a stuck starter motor.
- beddyfarmtruck
11 years 8 months ago #138820
by beddyfarmtruck
yeah that's the ford I mentioned in my introduction post, that's an old photo from before dad sold the ford
11 years 7 months ago #138821
by cam245
Replied by cam245 on topic Re: costs of DIY engine rebuild?
My MLK had a frozen engine when I got it and rather than free it up by force I decided to pull it apart and see why.
A number of the valves were frozen in the guides, about half of pistons had rings rusted in the bores, only about in 2 pistons the rings were free all the rest were stuck in the grooves, most of the lifters were rusted in their bores and the cam had surface rust all over the lobes.
There was so much sludge in the sump it was over the oil pump intake.
And more.
Thing is after stripping it down and cleaning everything up, honing the bores and lubing everything with assembly lube when I put it back together it started pretty much first go.
There are some things you can only tell if you open it up and have a good look inside.
And more.
Time to create page: 0.290 seconds
