Best chassis to use on a Dodge or similar.
11 years 8 months ago #145228
by toggle
Best chassis to use on a Dodge or similar. was created by toggle
Hi all,
I am wanting to build a rat rod truck using a D5N or some other type of late 50s early 60s body. I see that Holden tonner chassis are a popular choice but they seem to site quite narrow, would not an F100 chassis and running gear be a better option or are the just too wide??? any advice will be much appreciated.
Cheers.
Cheers.
11 years 8 months ago #145229
by plastic bertrand
Replied by plastic bertrand on topic Re: Best chassis to use on a Dodge or similar.
cant help except to say check what u r allowed to marry the cab too, many laws have changed regarding this depending on what state ur in, pay to check with your states motor vehicle modification dept, in sa you can do s.f.a except use the original chassis, then modify it via engineers specifications
11 years 8 months ago #145230
by nicco
Replied by nicco on topic Re: Best chassis to use on a Dodge or similar.
Can't remember where but saw one for sale online recently with L300 front suspension to get the drop up front. It is a popular conversion for rodders. Depending on your engineer/skills/budget you could Z the rear to get it down low.
11 years 8 months ago #145231
by toggle
Replied by toggle on topic Re: Best chassis to use on a Dodge or similar.
Thanks guys.
Looks like a lot of research coming up.
11 years 8 months ago #145232
Replied by bigcam on topic Re: Best chassis to use on a Dodge or similar.
Have you actually looked at a Holden chassis?
They are a perimeter chassis, meaning the rails go out nearly the sills.
As the others said, best to check first too.
Be interested in whatever you do.
11 years 8 months ago #145233
by toggle
Thanks BigCam, The main reason (and I havent measured or specced any chassises V bodies yet) is on the tonner chassis the wheels look to sit too far under the guards which is not a look I particularly like. Even with wide wheels I want them to fill the guards out more. Any thoughts?
11 years 8 months ago #145234
by tim
Replied by tim on topic Re: Best chassis to use on a Dodge or similar.
Morning Toggle I have a mid 1980's F100 short wheel base, rolling chassis here that is excess stock. I'm not sure where you are but if you want I can get some measurements off the chassis for you.
There is also a 1977 F100 SWB chassis here too.
If they're of any interest let me know.
Cheers Tim
Cheers Tim
11 years 8 months ago #145235
by toggle
Thanks Tim but Im in Qld.
11 years 8 months ago #145236
Quite a few AR/AL/AS Inters on Holden Chassis and there seems to be plenty of room for big tyres.
S'pose you'll have to get the measuring stick out.
Where abouts in Queensland are you?
11 years 8 months ago #145237
by toggle
thanks bigcam, im in caboolture. Its not so much the room for big tyres its that the ones i have seen have too much room left over. the tyres seem to sit too far under, i want mine to fill the guards out rather than be sitting under which look like they have a set of bike wheels underneath, if you get my drift. my old man was killed in a truck accident when I was 3 months old (1966) so I want to have something about his era, he had some inters and a commer (which is the one that he was killed in) and I want it to be like a shop truck and have his name and phone etc on the side....Fenwicks Transport Ph 270...how far we have come from the 3 didgit phone numbers...Lol.
Time to create page: 0.345 seconds
