Joey Box Question
11 years 4 months ago - 11 years 4 months ago #149165 by ianoz
Joey Box Question was created by ianoz
John Ford Asked me to see if he could get some info on a Joey box's Dana Spicer 5831
3000-18-7 bad internet here can you checkout what the over drive is and how strong they are please
it' was behind a 390 V8 Dodge
He is thinking about putting it in the Acco they just bought with 240 HP cummins and Auto box . Or possibly behind the 4 speed in his Ford F350 .
Last edit: 11 years 4 months ago by ianoz.
11 years 4 months ago #149166 by Dave_64
Replied by Dave_64 on topic Re: Joey Box Question
Came in several variations of ratio, IF you can get someone to hook onto the web for you, try "Spicer 5831"
I gleaned these, 5831A 1.54:1-1.00:1-0.73:1
5831B 2.35:1-1.00:1- 0.85:1
5831C 1.27:1-1.00:1- 0.85:1
There are also a "D" and an "F" series, but don't know the ratios. They are getting on a bit now, Chevy and GMC used them way back when. If it's in any reasonable condition, keep it alive! Getting hard to get hold of now. If your mate's running something like a Ford NP435 main box, they are the perfect compliment, especially if it is one of the close ratio versions. I have been also keeping my eye out for one for some time now.
Cheers, Dave 64
11 years 4 months ago #149167 by Dave_64
P.S.
If it came from behind the 390 Dodge truck motor, they were apparently quite a torque machine. Blokes in the states are sticking them behind 6BT turbo Cummins, GM 4-71's etc. They were able to withstand a fair bit, as you can imagine multiplying engine torque with lower gears in the main box. Like all those Spicer auxillaries, you just have to treat them with a bit of respect, especially as you may have trouble getting some parts for them!
Cheers, Dave
11 years 4 months ago #149168 by kenny-mopar
Replied by kenny-mopar on topic Re: Joey Box Question
Dodge 390 V8 motor ? Or maybe the 361 they were often used in them esp in old concrete agitators ... They were usually the .85 overdrive ill try to see what mine says on the tags over the next couple of daze
11 years 4 months ago #149169 by q4016lanz
Replied by q4016lanz on topic Re: Joey Box Question
Thanks Ian
The truck has a 6t 8.3 cummins auto was wondering if the joey box would be strong enough driving a boggy thanks everyone :)
11 years 4 months ago - 11 years 4 months ago #149170 by Blackduck59
Replied by Blackduck59 on topic Re: Joey Box Question
5831 without a suffix, 2, 1.1 , .73
5831 D 2 ,1.1 , .85
5831 E 1.27 , 1.1 , .73
5831 F, 2, 1.1, 1.27, double under
5831 G , 2 , 1.1 , 1.31, double under
Will add I have a 7231-D that came out of a Dodge, had a 5 speed in front of it but do not know what engine it had
Last edit: 11 years 4 months ago by Blackduck59.
11 years 4 months ago #149171 by mammoth
Replied by mammoth on topic Re: Joey Box Question
While on the subject I have a Dana joey with the following numbers;
Serial: SC 265V
BM: 300602 - 1
Model: 7231 D
What is it? There are two operating rods at the top.
11 years 4 months ago #149172 by Blackduck59
As above, my 7231-D came out of a Dodge
2.14 under, 1.1 and .86 Overdrive
11 years 4 months ago #149173 by mammoth
Thanks. Not much on the overdrive side - how would it go turned around to double the speed (we are talking old 30 mph jiggers here)?
11 years 4 months ago #149174 by Sarge
Replied by Sarge on topic Re: Joey Box Question
Mamoth, my mate with the 1956 Austin Motor home has got a 3 speed joey in back to front to give it some legs and works fine. I think the engine revs are still up a bit to maintain a reasonable highway speed, but it will run all day at 90 + kph.
/me
Sarge B)
Time to create page: 0.265 seconds
