903 cummins problems
11 years 3 months ago #149599 by
903 cummins problems was created by
Hi,
I have a few problems with my 903 in my acco, it is staving for fuel and am wondering if there are any tricks to bleed it. I see there is a bleed plug on pump is that all there is? I have check the fuel line from filter back to tank and tomorrow will check the line from tank to pump. I have been told that there could be a gauze near the pump. Any suggestions to check. I have loaded up already for a show this weekend so need to fix quick. Glad problem started at home though.
11 years 3 months ago #149600 by Blackduck59
Been that long since I have been around a 903.
Does it show signs straight away or after running for awhile.
What do they have for a lift pump? if anything like some other Cummins there maybe a screen/gauze filter in the pump inlet.
Any signs of leaks along the fuel line?, if it can leak fuel it can suck air into the system.
What does the fuel tank have for a breather?Not blocked?
How new are your fuel filters?
11 years 3 months ago #149601 by
Replied by on topic Re: 903 cummins problems
no lift pump, new filter today. every time I took it off the fuel was down 1 to 2 inches, topped up and refitted. Breather clear, fuel line from tank tank to filter clear. has fuel put more in. Will check line from filter to pump in morning when cab tilted. Motor would idle normal for only about 5 seconds then hunt like made and sound like a chaff cutter and plumes of smoke. Tried to bleed at pump, opened the 1/4" bung to bleed but there is also a large slotted screw which I could not move tonight which maybe the correct bleed screw to use.
Any other thoughts? Has to be something simple. Will check the 2 fuel lines for signs of holes but no visible fuel leaks so seems to be partial blockage somewhere.
Never had a problem though only owned it for couple months.
11 years 3 months ago - 11 years 3 months ago #149602 by
G'day pd2 .. i hope you get her sorted without too much drama mate.
...had a similar problem on one of the dealer repaints a few years ago...a 2238 Benz from memory. It ended up being a rag in the fuel tank :o :o ::)...
...it would drop off the pickup when not running, then block the pickup after a couple of minutes running!....what a PIA ;D ;D
11 years 3 months ago #149603 by geoffb
11 years 3 months ago #149604 by bigcam
Replied by bigcam on topic Re: 903 cummins problems
Most Cummins motors, 903's included will be slow to come back in the revs when they are low on fuel, fuel blockage or sucking air.
Take the pick up line off and put it straight into a bucket of diesel, that will tell you if there is an obstruction in the pick up in the tank.
If you don't find your problem there make sure the pick up line is clear, would be odd for it to be blocked though.
Sounds like you've already checked the filter.
Once you've ruled out the pick up in the tank, the pick up line and the filter, that only leaves the pump. They are pretty robust and don't often give much trouble.
Let us know how you get on.
11 years 3 months ago #149605 by
Thanks for the comments, going to shed with spanners in hand.
Well if 3070's had come out with a GM I would have bought one!
Will let you all know the outcome.
11 years 3 months ago #149606 by bigcam
Hey Paul, I just cut up a 3070 that had an 8V92N in it earlier in the week.
Can't go wrong with a 903 anyway.
They make just as much noise as a GM and sound as good.
They usually leak as much oil as a GM out of the valley covers.
And they use as much fuel as a GM.
11 years 3 months ago #149607 by Swishy
Replied by Swishy on topic Re: 903 cummins problems
Big C
M80
Jist which side of D fence U on
Go the screeemerz
11 years 2 months ago #149608 by
Well you learn something every day hey..
Never knew 3070s came out with GMs..let alone 8V92s..
Wow.
Can remember a T-Pot or two with 6V92s...
Still stick with the nine an thrippence but.. :D
Time to create page: 0.286 seconds
