- Thank you received: 4
d1310 inter resto
10 years 8 months ago #152378
by trucksyd
Replied by trucksyd on topic Re: d1310 inter resto
ahh, i was hoping for a bit more power,no worries, i have the stromberg on mine ,it goes ok, looks like it will have to do!
10 years 8 months ago #152379
by indianman
Replied by indianman on topic Re: d1310 inter resto
G'day Syd great looking little rocket you got there, the old man always used to swear by fitting a 300 beddy stromberg to his 281 reckons he used to get a bit more power and seemed to hang on a bit better than standard, just had to mod the linkage slightly
Jon
Jon
10 years 8 months ago #152380
by trucksyd
gday indian ,thank for that, so its a slightly bigger stromberg than mine your talking about. off the bedford?
10 years 8 months ago #152381
by AT4114
Replied by AT4114 on topic Re: d1310 inter resto
Hi trucksyd are you using flux core wire in your welder as it can be a little tricky to use as I've learnt replacing the floor pans in my AT4 top job mate keep us posted with your progress cheers Bryant
10 years 8 months ago #152382
Replied by asw120 on topic Re: d1310 inter resto
Hi Syd, Indianman might be onto something there. It reminds me the 281 Inters do have a smaller throat than would be expected (only 1 3/32" IIRC) same as 161 Holden? Probably jetted bigger. I figured it was because they don't rev much past 3,000, where as the Holden will go well past 4,000.
I did fit a late 202 carby to one to get it going, 1 11/32" ?
Bolt/flange size the same, but had to drill out the holes in the carby. I only did it to get it running, never had the throttle hooked up because it's on the wrong side and cable-operated. It did idle much better than a correct one I got later (no matter what I did to it, maybe vapourized better?)
So a Stromberg with a bigger throat may indeed go better (might need to grind the manifold throat out as well).
There are many variants of that carby and you can get adjustable main jets for them.
Cheers.
Cheers.
- Thank you received: 10
10 years 8 months ago #152383
by spinnerboy
Replied by spinnerboy on topic Re: d1310 inter resto
Hi Syd, AS120 is spot on with that Holley problem, they used that carb with a different base plate on the Flathead Ford motors 1949-1954. The problems he states are correct, I have a 1950 Ford and vapour lock/flat spot are real issues, and they are renowned for power valve problems. Using PULP helps a lot, the10% Ethanol fuels are a pig.
10 years 8 months ago #152384
by trucksyd
hi spinner, thats no good as i noticed the dual throat on the holley & thought it would go straight on , i,ll have to try something different to add more grunt to the old 281,at the moment i have the timing & carb tuned nice so it keeps up with traffic....
10 years 8 months ago #152385
by trucksyd
hi bryant , at the moment im using the wire you normally use with gas , although sometimes i use without gas , still learning!
10 years 8 months ago #152386
by indianman
G'day Syd yep single barrel Stromberg off a 300 beddy will be talking to the old boy tonight so will ask him what he remembers of the fitment but I think from memory the base plate is the same but throttle linkage a bit ( read minor change ) different, the orig inter air cleaner ( dry element ) also fits.
Jon
Jon
10 years 8 months ago #152387
by oldgmc
Replied by oldgmc on topic Re: d1310 inter resto
That Holley is also on the AA110 with the 240ci engine well I know of a 1959 one the has it
Time to create page: 0.305 seconds
