- Thank you received: 1619
1951 Commer QX R7 petrol oil filter
Your best bet might be to try Mr Filter in Sydney. They are very helpful and have even been able to mix two different small filters together to get the required length. A shorter length shoiuld work if you can put in a spacer or spring to keep the seal in contact with the head, and a smaller o/d shouldn't be a problem either.
Beaver@ Museum of Fire
- Hommie1973
Even in the truck range, part numbers depended on the year and model. The early 50s was the start of change from by-pass filters to full flow type, so this may affect the type of filter needed.
Hi Beaver, Just found on another engine i have here a brass plate with the Tecalemit name on it. FG 2334 is on this plate but i think it my be a Tecalemit number. Will look up that other Ryco number your had just maybe. Mr Filter my be an option also, both engines i have here had the Star type felt filters fitted to them. Be nice to find one of those good felt type filters. Will look at the Humber filters too but maybe they would be smaller. I will keep looking, Thanks everyone for your ideas, Cheers Hommie
That is the number I quoted earlier, so at least we've got the model right.
The Ryco number does not come up in a search of their web site, but you could always ring them up, they have a good customer service hotline.
- Hommie1973
