1951 Commer QX R7 petrol oil filter
- Hommie1973
10 years 4 months ago #159208
by Hommie1973
Replied by Hommie1973 on topic Re: 1951 Commer QX R7
- Hommie1973
10 years 4 months ago - 10 years 4 months ago #159209
by Hommie1973
Last edit: 10 years 4 months ago by Hommie1973.
10 years 4 months ago #159210
Replied by asw120 on topic Re: 1951 Commer QX R7 petrol oil filter
Always good to see another oldie being saved.
Cheers, Jarrod.
Cheers, Jarrod.
- Hommie1973
10 years 4 months ago #159211
by Hommie1973
Replied by Hommie1973 on topic Re: 1951 Commer QX R7 petrol oil filter
- Hommie1973
10 years 4 months ago - 10 years 4 months ago #159212
by Hommie1973
Last edit: 10 years 4 months ago by hayseed.
- Thank you received: 7600
10 years 4 months ago #159213
Replied by Mrsmackpaul on topic Re: 1951 Commer QX R7 petrol oil filter
looking good there so you have the oil filter problem sorted now by the sounds of it there will be no stopping you now
- Hommie1973
10 years 4 months ago #159214
by Hommie1973
Hi Paul, I think i have it sorted, i have a Fleetguard LF3769 coming as we speak and i hope it will go close to doing the job. Almost ready to refit the motor just doing the final small things, distributor and fuel pump etc. Also fitting a ww stromberg carburettor which should take out any flat spots. Will see how it goes, Cheers Hommie
- Hommie1973
10 years 4 months ago #159215
by Hommie1973
Hi, Well i just fitted the Fleetguard LF 3769 and it was a good fit. Other Filters the same as the Fleetguard LF 3769 are Baldwin P 7196, and Donaldson P 550563. So any one wanting a cartridge filter for the early Commer sloper petrol motor either of these above filters will do in place of the OEM filter. You will need to either cut out or find a square o ring for the top of the canister as the o ring supplied with the filter will not do as it is a lot smaller and is not square profile. Hope this may be of help for other restorers looking for a filter cartridge for the early Commer. Hommie
10 years 4 months ago #159216
Replied by Cunning Stunt on topic Re: 1951 Commer QX R7 petrol oil filter
Hi Homie, here's a bit of inspiration. This was my Dad's R7, photo taken in 1955. Great job you're doing there pal.....
10 years 4 months ago - 10 years 4 months ago #159217
by defective
Replied by defective on topic Re: 1951 Commer QX R7 petrol oil filter
those petrol R7's must've been hard work on a stinking hot day .. no front panel vents on those early ones, and no 1/4 vent windows in the doors ...( i s'pose you flipped out the front screens early days ?)
Last edit: 10 years 4 months ago by defective.
Time to create page: 0.388 seconds
