steering bump
9 years 5 months ago #174959
by Rustyb
Replied by Rustyb on topic steering bump
Hi Fill and all you guys with the suggestions.
I have 1 wedge that I removed from the drivers side and on it is marked front with the number 4 stamped on it, I am now trying to get another wedge for the other side just in case I need to use them.
I now have the manual, I have taken measurements of the axle and springs clearences from the ground and all are near perfect, I will try now all the suggestions that you guys have given me and come back to you all when problem solved.
Thanks again for all your helps.
Kind regards
Russ
Kind regards
Russ
9 years 5 months ago #174960
by Rustyb
new bearings fitted running smooth as.
9 years 5 months ago #174962
by Rustyb
shocks are new munroes, numbers were crossed referenced by them and you would/nt know it they were the same, will take them off and give it ago without them.
Russ
Russ
9 years 5 months ago #174963
by Rustyb
All look and feel good but will double check.
Russ
Russ
9 years 5 months ago #174981
by Rustyb
Hi Steve,
We live in Elland via south grafton nsw on the far north coast , but currently holidaying in Sydney.
Kind regards
Russ
Kind regards
Russ
- Thank you received: 582
9 years 5 months ago #174982
Replied by Blackduck59 on topic steering bump
Russ,
Tad far to drop in for a look.
Cheers Steve, WA
Cheers Steve, WA
9 years 5 months ago #175100
by Rustyb
Just noticed the drag link has a bend of about 4-5 mm on end closest to the driver, are these normally bent and if not can I press it back and if not does anyone have one for sale.
Rustyb
Rustyb
9 years 5 months ago #175124
by Fill
Replied by Fill on topic steering bump
Hi Rusty
Just went out and checked mine. The rod is straight as far as I can see. I will have a better look tomorrow in the light. If you buy a new one make sure it is for your truck left or right hand drive. They look almost the same. I got mind from Auto Surplus in Rooks Road Mitcham Vic ph 03 9873 3566 -speak to Bermie and tell him that Phill Quinn with the Bedford said to ring.
9 years 5 months ago #175136
by Fill
Hi Rusty
This is the old one
100_2848
fill quinn
, on Flickr
100_2847
fill quinn
, on Flickr
Hope this helps Cheers Fill
This is the old one
9 years 5 months ago #175137
Replied by Swishy on topic steering bump
Fill gudday M8
with fixd end ti rod how do u adjust toe in/out
thanx in advance
thanx in advance
Time to create page: 0.298 seconds
