- Thank you received: 257
Big Dodge hydraulic brakes
6 years 11 months ago #181966
by 600Dodge
Big Dodge hydraulic brakes was created by 600Dodge
Are all Dodge brake bleeders on the bottom side of the backing plates? I vacuum bleed mine so it isn't a problem but what about if you manual bleed and all the air goes to the top?
6 years 11 months ago #181970
by jeffo
Replied by jeffo on topic Big Dodge hydraulic brakes
Don't know about your Dodge but whenever I see bleeders on the bottom (on cars/4WD's) someone has fitted the brake assemblies incorrectly side for side.
6 years 11 months ago #181975
by 600Dodge
Replied by 600Dodge on topic Big Dodge hydraulic brakes
That was my first thought also, mine looks to never have been apart but I could be wrong.
6 years 11 months ago #181980
Replied by JOHN.K. on topic Big Dodge hydraulic brakes
At one time most trucks were serviced from a pit,so bottom bleeders were accessible.
- Thank you received: 29
6 years 11 months ago #181984
by Dodgeanddetroit
Replied by Dodgeanddetroit on topic Big Dodge hydraulic brakes
6 years 11 months ago #181987
by 600Dodge
Thanks Dodgeanddetroit, that looks identical to mine, I didn't even think to compare it to my 700.
6 years 11 months ago #181990
by jeffo
I think that will bleed conventionally OK.
The oil flow is in at the bottom of the top wheel cylinder then out at the top.
And then off to the bottom of the lower wheel cylinder and out at its top.
Have seen worse.
Have seen worse.
6 years 11 months ago #181995
Replied by asw120 on topic Big Dodge hydraulic brakes
I had all hell trying to manually bleed the front brakes on a 510 ACCO. We worked out, if you had someone else in the cab pumping like mad, you could get all the air out. Hated it. Stupid upside-down wheel cylinders. (bleeders not at the top)
6 years 11 months ago #181998
Replied by Swishy on topic Big Dodge hydraulic brakes
Twaz always told wen bleed n brakes start @ the furthest bleeder from the master cylinder n work U way back till all dun
wen pumping hold full pressure till the bleeders in nearly all dun but make sure U tight n up B 4 there B no more pressure
Butt
Wadda Eye Kno
Butt
Wadda Eye Kno
6 years 10 months ago #182020
Dont waste ten gallons of fluid,make yourself a pressure bleeder from a garden sprayer.Then fill the brakes with fluid from the lowest point.Fluid is heavier than air,so it pushes the air out,rather than trying to wash out the air with a rush of fluid from the top.Works good on the impossible to bleed clutch master cylinders too.
