- Thank you received: 4
Choosing a replacement diff housing
I've been informed that my Thames is rather slow, and having only driven it in the driveway in 1st and reverse, i can only trust what I've been told. I have discovered that the diff ratio is roughly 6:1. This combined with the mechanical drum breaks means that I've decided to change the diff housing to something a little more modern.
What should I been looking for when choosing a replacement?
Obviously a lower ratio and hydraulic breaks, but what else?
Thanks in advance
- Thank you received: 599
Would a hydraulic brake conversion need to be engineered?
Might end up easier and cheaper to leave home 20 minutes earlier and just sit back and enjoy the ride................
- Thank you received: 4707
If you only have say 750 / 20's on there maybe change to 10.00's as these are a lot taller and will go onto the narrower rims with some effort
Also buy a cheap tacho and just check the revs at different speeds just to see for your self how fast it revs
6-1 is pretty handy diff ratio as plenty of trucks were around this or slower
But leaving home 20inutes earlier to me is the simplest answer by far and allows for a more relaxed cruise as these slower vehicles can be a bit of a handful when geared right up and most don't have the power either
Roughy wrote: Hi All,
Thanks in advance
Mechanical brakes??? What year model is it?
i.imgur.com/hIQu4jY.jpg
i.imgur.com/35loaEk.jpg
Yes that be a torque tube.
Overnite: I believe it's a 1956 model
Another issue is getting my hands on grease and oil seals so that this doesn't happen again,
i.imgur.com/g2SNuaT.jpg
i.imgur.com/N3ZZJkK.jpg
i.imgur.com/ovSPdiB.jpg
