- Thank you received: 3
Suspension swap
5 years 11 months ago #192941
by ar110
Suspension swap was created by ar110
I'm trying to do a quick build and currently have an AT4 114. Chassis currently has no suspension but recently took delivery of a 229 with a spare inter 5 stud disc brake front end so I thought I would use that on the 114 and put a matching rear diff. Am I correct in assuming they are straight swap or are there things that need changing.
The other question is. What model and size inters would I need to be looking at to get a matching diff to the front end.
Cheers in advance
Cheers in advance
5 years 11 months ago #192949
by Eddy
Replied by Eddy on topic Suspension swap
No law says you need to match the front and rear wheels. Many vehicles come with different front-rear wheel sizes and designs. Long as you have a spare for each end it's all good.
5 years 11 months ago #192950
by ar110
Replied by ar110 on topic Suspension swap
Thanks for your response Eddy. I didn't think it would be an issue but theres not a lot of room to carry 2 different patterned spares in a 114 tub hence the reason for looking for matching front and rear.
I guess it doesnt necessarily have to be inter either as long as I can find the same stud pattern. Anyone know the PCD of the 60's 5 stud inters.
5 years 11 months ago #192952
Replied by asw120 on topic Suspension swap
5 on 4 1/2" - same as Falcon.
5 years 11 months ago #192954
by ar110
Thanks for that Jarrod.
I just remembered I have an AS110 diff with springs I was trying to sell a while back. Are they the same diff as the later C and D models or were they changed.
I managed to also track down a CJ10 Dana 60 with springs. Will that fit or are they too wide and different stud pattern
5 years 11 months ago #192956
An AS110 diff is the same part as an AA / AB 110 diff (except AB went to 3.73 ratio, I think). It will go straight in. Springs are different, though. They won't fit.
Don't know if the Jeep diff will fit, although it could be made to fit.
5 years 11 months ago #192957
Replied by JOHN.K. on topic Suspension swap
The 110 IH diffs have parts that are always broken,and probably unobtainable.Your Dodge will have a Dana 60 diff,as did the D line inters.But the Dline Inters had disc brakes that are fantastic.PBR calipers same as a Ozzie car.
The following user(s) said Thank You: ar110
5 years 10 months ago - 5 years 10 months ago #193654
by ar110
John K. Unfortunately my chassis doesnt have anything atm hence chasing the Inter diff to match a front Inter Axle I recently acquired as a spare with my 229 .
Is there anyone in the Perth region or know of anyone with a single wheel C or D line Inter diff surplus to their needs and willing to part with it.
Cheers in advance. Mick
Last edit: 5 years 10 months ago by ar110.
Time to create page: 0.482 seconds
