- Thank you received: 537
Rockwell SLHD wheel bearings
5 years 10 months ago #193666
by Oilman
Rockwell SLHD wheel bearings was created by Oilman
When I disassembled the diff the wheel bearings were grease filled. When I went to buy new seals I was told that the second seal was no longer fitted and the wheel bearings are oil filled by the diff oil. All this makes sense, but I can't find anything to confirm this. Just wanted to check if this is true? If so, I think the only thing I need to do is after I fill the diff with oil is to jack up either side of the axle to allow oil to fill the hubs and then top up the oil.
5 years 10 months ago #193669
Replied by Swishy on topic Rockwell SLHD wheel bearings
OilMan
gudday m8
yes the ol way was oil in the diff n grease in the wheel hubs with a good seal BTween the 2
nowa days diff oil flows from hub to hub with a huge resevoir of oil in the diff
also the hub have a plug to drain or add oil
yes jack side up to let the oil run thru n go have a wee earned sip or 3 then jack the other side to get oil thru to th@ said n check diff level again
ยง
gudday m8
ยง
5 years 10 months ago #193671
by werkhorse
Replied by werkhorse on topic Rockwell SLHD wheel bearings
What we used to do was smear grease on the bearing and FIL the hub up between the Two bearing cups with oil... That way the grease would lube the bearing for the short time before the oil started getting about.... You'd be surprised at how much oil makes it's way out to the hubs from the centre
5 years 10 months ago #193673
Replied by JOHN.K. on topic Rockwell SLHD wheel bearings
The hand pushin plastic unit type are fantastic.......they get around all kinds of housing damage,and seal perfectly..........I once forgot a inner bearing,pulled the seal out,which is a no-no,refitted the seal and everything worked perfectly.......But when they start to leak,theyrs worn out,and will flood oil in short order.....I reckon they are the biggest improvement in trucks since the horse and cart days.
Time to create page: 0.466 seconds
