- Thank you received: 407
Split rims
5 years 6 months ago - 5 years 6 months ago #196616
Replied by Lang on topic Split rims
Here is a great guide to truck rims. Could almost be called The Bible on Rim Fitting.
I would guess if you got into your rims with a wire brush in the grooves and flanges you would probably be OK. There has to be a gap because if they were touching there is the chance the ring is actually being held open out of the groove.
www.accuridecorp.com/files/2012/10/Accur...2-Rev-4-06-22-12.pdf
Last edit: 5 years 6 months ago by Lang.
5 years 6 months ago #196618
Replied by Swishy on topic Split rims
Az Lang Sez
clean the groove n match bit on the lock rim
then wen assembled up with about 10-20psi (all dun in an enclosed tyre cage of corse)
tap the lock rim opisite the gap part to try and close the gap up a bit by tap n oposite then keep tap n as U wortk your way around to the split gap working both ways from oposite ..... U may C the gap close a little as the groove n other bit marry up snug
if n U get my drift
if n U get my drift
5 years 6 months ago #196624
Replied by jon_d on topic Split rims
Thanks Gents.
I'll give them a good clean.
So, if I can confirm from your experience, the ring gap closes when the tyre is fitted and filled.....
The current gap is 17 mm and I can't mentally see how it will up 10 mm or so.
5 years 6 months ago - 5 years 6 months ago #196625
Jon
Just walked around my old Commer, which probably are the same wheels as your Bedford, and I figure the average gap is around 15mm for the 4 wheels I can see easily.
You are not talking piston ring gap or Swiss watches and your wheel looks pretty clean and corrosion free. I still think with a wire brush you are on a winner.
This is a first class guide to rim assembly and safety.
www.bcforestsafe.org/files/Split%20Rim%20Safety%20July%2017.pdf
5 years 6 months ago #196635
Replied by cobbadog on topic Split rims
What you have is perfectly safe to use but as suggested get into it with a wire brush wheel on an angle grinder to ensure that it does go together well when fitting the tyre. I spent too many years fitting truck tyres and forklift stuff as well.
With those old ones use plenty of lube on the bead of the tyre so that as you inflate it slips along nicely. As mentioned it is best to do this in a cage but many of us survived to an older age with out one but always alert to what can go wrong. Another tip is to use talc powder inside the case so that the tube does not cause too much friction and then heat when travelling along roads.
Tap the lock ring constantly all the way around and as suggested start from opposite the gap of the lock ring and working each side towards the gap. You must keep doing this until both beads are well seated against both flanges. Once they are seated you can relax and inflate to your working pressure.
5 years 6 months ago #196643
by Bitsa
Replied by Bitsa on topic Split rims
I'm not a expert in tyres , but i have fitted and removed i think may be in the thousands of them and i think Cobbadog has hit the nail on the head.
Clean the Rim and the Ring and tap with a hammer all the way around as stated, starting opposite the gap, filling slowly so you can check the pressurisation process
as you go. If you have a tyre cage , it's a good idea if your not very experienced. I have seen them seperate and it's not a good thing to be close to when it happens..
Hope this post is helpfull.
Alistair
Alistair
5 years 6 months ago #196645
Replied by JOHN.K. on topic Split rims
The most dangerous truck wheels I have ever seen are the Budd wheels fitted to big US WW2 trucks like Macks and Diamond T s......easily spotted as the locking collet is held to the side ring by two rivets......these rings can blow off at any time,even when the wheel is on the truck.....The safest would be the old trailer rims with a big ledge inside the bead,like the Bedford one shown.......A Sankey Benson ,I think.......Dunlop rims were a bit different ,as were Rubery Owen.,and there are important differences between med and HD wheels and lock rings.
5 years 6 months ago #196718
by V8Ian
Replied by V8Ian on topic Split rims
If you don't have a cage, you can use each end of a hooked chain at 9 and 3 o'clock to the gap.
