1934 International C1
1 year 2 months ago #254719 by wee-allis
Replied by wee-allis on topic 1934 International C1
Great memories, but I think more a Fiat bodied Hudson. LOL.
The following user(s) said Thank You: overnite
5 months 3 weeks ago - 5 months 3 weeks ago #258650 by Southbound
Replied by Southbound on topic 1934 International C1
In the time I’ve had my ute it has never idled properly so I’ve been over the carby and the intake manifold a few times, tried two other carbys, replaced all of the engines ignition parts and even made up new copper HT leads but to no avail. I was looking at the intake manifold from my spare engine and noticed a copper tube in it.
Then upon dismantling the manifolds found a tin sheet between them to block off the exhaust gas.
Last edit: 5 months 3 weeks ago by Southbound.
The following user(s) said Thank You: 180wannabe, cobbadog, Mrsmackpaul, PaulFH
5 months 3 weeks ago - 5 months 3 weeks ago #258651 by Southbound
The intake throat in the manifold has no parent bore and a steel sleeve in it, I presume it was easier to cast the manifold that way or maybe it’s for quicker warm up in cold climates, whatever, it had a hole in it and I’ve finally found the problem.
So I turned up a sleeve, pressed it in and now it idles nicely.
The following user(s) said Thank You: 180wannabe, cobbadog, Mrsmackpaul, Normanby, PaulFH, asw120, Fighting Rust, wee-allis, oliver1950
5 months 3 weeks ago #258652 by PaulFH
Replied by PaulFH on topic 1934 International C1
Nice to find the cause and be able to repair.
Uncle reckoned when you lift a bonnet there should be a red arrow pointing to the problem.
The following user(s) said Thank You: 180wannabe, cobbadog, Mrsmackpaul, Southbound, wee-allis
5 months 3 weeks ago #258661 by Gryphon
Replied by Gryphon on topic 1934 International C1
Hi.
my understanding of the shared inlet and outlet cast manifolds is it allows the heat from the exhaust to keep the inlet warm to prevent the air fuel mixture from forming droplets on the sidewalls as it makes its way to the cylinder head, keeping the mixture even and airbourne. On BMC A Series you can notice a definite lag, measured in seconds, on really cold evenings if you replace the exhaust manifold and just use the cast inlet with no heating.
Terry
The following user(s) said Thank You: cobbadog, Mrsmackpaul, PaulFH, Southbound, wee-allis
5 months 3 weeks ago #258664 by Mrsmackpaul
Replied by Mrsmackpaul on topic 1934 International C1
Good job finding that issue
There was someone on the forum many years ago who must of had a similar issue on a inline type of motor
That was the first I had ever heard about the heat from the exhaust keeping the air/fuel vapor in the correct state for the further away cylinders
Good to finally find the problem and better yet, to fix the issue
The following user(s) said Thank You: cobbadog, PaulFH, Southbound
5 months 3 weeks ago #258673 by cobbadog
Replied by cobbadog on topic 1934 International C1
The old Holden grey motor had a butterfly below the inlet for this reason. Originally it was spring loaded. All of that lasted 12 months at best then the spring lost its tension n the butterfly rusted in place.
I like the idea of a red arrow pointing to the problem. I could do with one for my David Brown tractor. It's miss firing again only this time I'm thinking sticky valve/s.
The following user(s) said Thank You: Mrsmackpaul, PaulFH, Southbound
5 months 3 weeks ago - 5 months 3 weeks ago #258685 by Southbound
Went for a drive to Noojee today.
The following user(s) said Thank You: allan, 180wannabe, cobbadog, Mrsmackpaul, PaulFH, wee-allis
5 months 3 weeks ago #258686 by Southbound
The following user(s) said Thank You: 180wannabe, cobbadog, Mrsmackpaul, PaulFH, asw120, Fighting Rust, wee-allis, oliver1950
5 months 3 weeks ago #258688 by Mrsmackpaul
A mountain man up in the mountains
I trust the idle issue remained fixed
Been a few years (lotta years) since I have been to Noojee
The following user(s) said Thank You: 180wannabe, PaulFH, Southbound
Time to create page: 0.375 seconds
