Strange attachments on front brakes.
4 years 11 months ago #200493 by Linz1607
Hi guys, hoping someone can assist. I was under the truck yesterday and noticed someone has welded a bit flat bar on the bottom edge of the front brake backing plates, and welded to this flat bar are 2 chain links about 6" apart. All the links show wear as if another link or wire rope was attached and maybe stretched between to 2 wheels. Any idea what these where for?
4 years 11 months ago #200494 by Dave_64
Home made "Sure-Guides" ???
The following user(s) said Thank You: Linz1607
4 years 11 months ago #200497 by Swishy
Would/Should/Could B
Shure guide
The following user(s) said Thank You: Medicated Mick, Linz1607
4 years 11 months ago #200501 by overnite
I’ll second that. We had these fitted to the first batch of ghosts.
4 years 11 months ago #200504 by cobbadog
Seeing how it appears to be acceptable to ask "dumb ass questions" on here......what are sure guides please?
4 years 11 months ago #200506 by Dave_64
Someone here will give a better explanation, but basically way back in the days before power steering, shur-guides were fitted across the steering to assist control on rough roads, on narrow Oz roads, as even today, drop the near side (passenger) side steer tyres off onto the dirt and she would head for the scrub. On a cab over especially, at least gave you some sort of control. Yank idea from memory, Swishy’s photo sort of tells the story. Once power steering became the norm, went out of vogue. Personally thought they were a good idea, at the time. Overnite may be able to give you his opinion.
4 years 11 months ago #200508 by Swishy
Not sure wot linz has there
but the one fear of all truck drivers were a blow out on a steer tyre
th@ would put U off the road n in a ditch ................... or worse
here R the rest of Shure Guide info
Now the X Spurts R tell n us different
[img
Clikity ......................................................................ClikClikClik
The following user(s) said Thank You: IHScout, cobbadog
4 years 11 months ago #200509 by hayseed
cobbadog wrote: Seeing how it appears to be acceptable to ask "dumb ass questions" on here......what are sure guides please?
No such thing as a "Dumb Question" cobbadog.....Only way We all Learn..
4 years 11 months ago #200513 by JOHN.K.
You want dangerous...drive a Franna Crane........if you hit a high kerb,the crane jacknifes into the kerb,and climbs it........and if you bounce on a big pothole at 100ks,where you land is a big gamble...........a truck automatically goes straight ahead,with a Franna ,the tendency is to jacknife and flip over.
4 years 11 months ago #200519 by overnite
Dave_64 wrote: Someone here will give a better explanation, but basically way back in the days before power steering, shur-guides were fitted across the steering to assist control on rough roads, on narrow Oz roads, as even today, drop the near side (passenger) side steer tyres off onto the dirt and she would head for the scrub. On a cab over especially, at least gave you some sort of control. Yank idea from memory, Swishy’s photo sort of tells the story. Once power steering became the norm, went out of vogue. Personally thought they were a good idea, at the time. Overnite may be able to give you his opinion.
Could not have explained it much better myself . Before they fitted ShurGuides to the early ghosts, you almost had your arms ripped out of their sockets trying to back on the bitumen after you dropped the LH steer in the dirt.
Time to create page: 0.614 seconds
