- Thank you received: 18
CO4070 Cabin lift pump
4 years 10 months ago #200851
by CO4070
CO4070 Cabin lift pump was created by CO4070
Hi all
Wondering if someone knows where i might get a cabin lift pump to replace my original one.
I have taken apart but think it is too worn to repair and was wondering about after market options
Greg
Greg
4 years 10 months ago #200872
by Oilman
Replied by Oilman on topic CO4070 Cabin lift pump
The one off my Atkinson was pretty shagged but I managed to repair and get it back together. Mind you I haven't used it yet so not 100% sure it is OK. Yours may still be worthwhile trying to repair.
www.hcvc.com.au/forum/restore/17301-atkinson-cab-hydraulic-pump
The following user(s) said Thank You: CO4070
4 years 10 months ago - 4 years 10 months ago #200878
Replied by JOHN.K. on topic CO4070 Cabin lift pump
I cant see it being hard to repair.........at the very worst ,a few new packings and seals.......not as tho the cylinders would be worn out from use,even if you tilted the cab once a day.......I used to repair tele hoists been lubricated with sand.,and used on twisted bodies.......if you use a different pump ,you ll be up for hoses and fittings ,which aint cheap.
Last edit: 4 years 10 months ago by JOHN.K..
- Rattail 1927
- Thank you received: 66
4 years 6 months ago #203262
by Rattail 1927
Replied by Rattail 1927 on topic CO4070 Cabin lift pump
Not sure where I heard it but one off a cab over kenworth ( air operated ) will fit with minimal effort, plus the bonus of air ... press the button
4 years 6 months ago #203285
Replied by cobbadog on topic CO4070 Cabin lift pump
I wonder how he got on with the pump?
4 years 6 months ago #203294
Ive yet to see one couldnt be fixed by replacing the packings or a leather bucket in the cylinder.leather will tolerate rough surface from rust.
4 years 6 months ago #203425
by CO4070
Replied by CO4070 on topic CO4070 Cabin lift pump
Hi everyone thanks for you input . Have pulled apart an think that i should be able to re use ok
4 years 6 months ago #203427
If you strike trouble,take it to one of the repairers who fix htdraulic jacks,trolley jacks and portapowers.....they have usually got the packings and buckets,and usually have a small honing machine to clean up the cylinders if needed.
- Thank you received: 1174
4 years 6 months ago #203449
by Southbound
Replied by Southbound on topic CO4070 Cabin lift pump
If you need any hydraulic seals or any odball seals try Metric Seals in Bayswater Vic.
Time to create page: 0.554 seconds
