Rockwell R170 outer bearing locknuts missing
4 years 7 months ago #202151
by roKWiz
Heritage Stonemason
Rockwell R170 outer bearing locknuts missing was created by roKWiz
This one has me puzzled.
I was in the process of disassembling the axles for brake replacement / drum removal where I seem to be missing the threaded outer casing and locknuts usually found on these housings.
Picture show one large bearing housing and no way of getting around it. Anyone know how this comes apart.
Appreciate the help.
Heritage Stonemason
4 years 7 months ago #202158
Replied by Swishy on topic Rockwell R170 outer bearing locknuts missing
RokWiz
m80
the olden days they had a seal as U pictured
mainly to keep the bearing grease from enterin the diff oil
n vise versa ... diff oil enter n the hub grease
Fast 4ward to the new millinium
they dun away with th@ seal so the diff oil can supply oil to the hub bearings etc all in one
BHind the seal U should find the lock nut , tabd locking washer n bearin adjusting nut
m80
The following user(s) said Thank You: roKWiz
4 years 7 months ago #202164
by roKWiz
Heritage Stonemason
Replied by roKWiz on topic Rockwell R170 outer bearing locknuts missing
Thanks Swishy,
I didn't want to rip into to it without checking first. Yeh, an old R170 parts book I have doesn't even show it.
Thanks again.
Thanks again.
Heritage Stonemason
Time to create page: 0.409 seconds
