Ernie came back again, earlier than normal (cos his wife is away) and we got stuck into a serious days work . . .until the mig wire ran out
which meant a round trip into Port Pirie (one hour) before we could get back into it. Sheet metal around the rear guards now (generously) tack welded into the frame work on the inside.
I appreciate this is not very clear (what's new?) but the hole behind the guard will (probably) be a side door for a storage box, both sides. Next job for me now will be to unbolt the rear guards so the joint between side panels and the outer mounting face can be fully welded (no holes around the bead). I slipped the upper sheet metal on quickly for pictures, although there is a reasonable amount of titivating before it will be totally ready, with a horizontal side "rubbing strip" about 3/4" above the guard. The idea of this is to conceal the overlapped sheets (upper/lower) and the tek screws holding upper and lower sheeting along the frame rail. The upper tekkies will be hidden by the overlapping piece along the top of the picture. (Clearer???
Apart from this various joints around the frame that were finish welded Erie also attacked the driver's side floor that had a star shaped split in the middle
, and some mountings added at the rear to bolt the rear bumper bar on.
All in all a lot was done, I'd be lost without Ernie - although I would probably just soldier on with my stick welder . . .
