The metal is 0.5 zincalume, the tray is approximately 3.8 metres long and the largest sheet metal I can find is 2.4 x 1.2 metres - necessitating two sheets along the length. The lower section is made up of two strips (each made up of a rear and front section):- one from the bottom to about 6cm above the top of the guard, and the other up to the step section and overlapping the lower strip by about 5cm. This could have been done with two full height pieces with one overlap at the "halfway" mark, but would have been unwieldy to manoeuvre by myself. Also possible damage to the lower sections will be simpler with the narrower strips. The reason I haven't gone too far with the turret at this stage is because I need to work from the back to the front, and then up one level, after which I will have to do some finishing work on the step section directly below the turret.
i.e. The turret can wait until I get to it.
cobbadog: I've experimented with clamps and pulling it around the curve, adding the extra support pieces to eliminate the tendency it had (without them) to fold rather than curve with moderate success. I have not found anybody with long enough rollers to form the curves for me, and even looked at using sections of large half round guttering - but ridiculously cost prohibitive. As for the knots, unnecessary from what I've seen so far. I should have minimal problem dragging it around the curve once the lower section is tekd along the lower edge and up the uprights. then around the curved frame work to be cut to suit the edge of the lift up roof hole. All the visible teks will be replaced by blind rivets when done.
Zuffen: I've attempted this with varying sections of pipe (oxy bottles are about the right diameter, good thinking) but very hard trying to control a 2.4 metre length of sheet metal and a large diameter piece of pipe at the same time. If I had persisted I would have crimped and damaged more metal than I can really afford! "Not an easy task." sums it up nicely; my recommendation to others contemplating anything like this is to build a tray top and enjoy it much sooner!?
Mrsmackpaul: Ratchet straps seem like a good idea and controllable too. Not fussed about the rivet free look, many early tanks and boilers had rivets in them. If you could locate the link it would be appreciated.
If all else fails I might opt for aluminium sheeting up on the turret instead . . . easier to bend???
Whatever, knowing me though I'll probably make a corflute mock-up first, just because that will be an easy way to see how the top will look when done.
