- Thank you received: 2962
Adding a power brake booster.
3 years 11 months ago #210283
Replied by cobbadog on topic Adding a power brake booster.
Not wanting to confuse the situation as my thoughts are to use the VH80 or 90 vacuum assist unit.
But for those who are looking for a power booster with a dual circuit master cylinder and it is a small unit have a look at the early Datsun brake units. They are small in size and were being used for remote brake set ups on hot rods.
3 years 11 months ago #210288
Replied by Dave_64 on topic Adding a power brake booster.
Yeah, Thanks Cobba, my own personal application a Dasun would be way too small, I would think. But handy for others to know Dave
3 years 11 months ago #210289
by Zuffen
Replied by Zuffen on topic Adding a power brake booster.
Why can't you change the master cylinder on VH style unit to get what you need.
I used once as a clutch assist for a 50kg wife I once had on an old 186 powered 2A landy.
Never looked to see if they could be altered.
3 years 11 months ago #210290
Replied by Lang on topic Adding a power brake booster.
I think Dave said there was not enough room for a master cylinder combined unit in his setup
3 years 11 months ago #210296
Zuffen, Lang nailed it, simply not enough room under cab where m/c sits, thats why has to be remote. Have seen one set up with 3/4" thick rod with dog leg in it to reach the master /VH set up. Didnt like the way it was set up
3 years 11 months ago #210298
PDU, question for you at short notice! Your the Bedford man, do you know of a Bedstead rim that is 6 stud and will take a 7.00 or 7.50X16" tyre? May be going back a bit, late 60's---early 70's?
3 years 11 months ago #210302
Dave
If you give us the pitch diameter of your wheels I can look for matching patterns from all over.
3 years 11 months ago #210305
Replied by PDU on topic Adding a power brake booster.
J1/2/3 Bedford's have a 6 stud 16" rim
Sorry I'm not sure of size as I didn't look very closely at the ones I had on my "engine donor" J series as B for has 8 stud wheels and I might have had trouble bolting them on!? :lol:
I gave them away with the remnants of the truck to the guy who moved the truck and pulled the engine out for me. Although I could have salvaged more gear from it this was an easy, on the spot, arrangement that saved me having to drag it 180km home!
3 years 11 months ago #210311
Lang/PDU, reason asked is that I have been told that Karrier 16" rims are interchangeable with some 6 stud Bedford. I dont have the PCD or hole diameters here at the moment, but should be able to dig them out. Pretty sure they were made by Sankey, but that may not tell us much as they probably made rims for half the Brit industry. I am also pretty sure that the measurement from inside lip to inside lip is 6". Supposed to take both 7.00 and 7.50 X16" tyres. The Karrier that I'm in the process of obtaining doesnt have a spare. Thought possibly Bedford may be easier to get than Karrier in 16's
Time to create page: 0.459 seconds
