Updated 28th July.
Welcome, Guest
  • Page:
  • 1
  • 2
TOPIC:
76 ACCO 510A 24 Oct 2020 12:06 #215678
  • Abbuss
  • Abbuss's Avatar Topic Author
  • Thank you received: 3
Steering column is a bit wonky,not sure whats wot in there but it must be a bush or two. Any help with supplier source or diagram would be greatly appreciated. It is probably easy peasy to get at. Abbuss
Last edit: by hayseed.
Door Window Track Runner 76 ACCO 510A 24 Oct 2020 12:22 #215680
  • Abbuss
I have rattly windows. The runners are worn out. If anyone knows where to get the fixit bits it would be greatly appreciate .Regards Abbuss
Door Window Track Runner 76 ACCO 510A 24 Oct 2020 12:55 #215681
  • Lang
  • Lang's Avatar
  • Thank you received: 2586
Just look for "window Channel" on Ebay. Every type and size available by the metre to just glue in the old frame.
Here is the waterproof type but the old "U" shape is readily available. Just measure the frame gap and buy the channel to suit.
www.ebay.com.au/itm/AUTOMOTIVE-WINDOW-CH...OCKING-/233225818282
The following user(s) said Thank You: Abbuss
Steering Column Bush 76 ACCO 510A Wanted 24 Oct 2020 14:23 #215684
  • asw120
  • asw120's Avatar
  • Thank you received: 254
If the same as lighter Inters, it's a bearing. I forget if it's in the coffee pot, or the top of the column.
Mike Calcutt at Fleetparts would be able to get you one, if they are available. Would be a standard Ross / TRW part.
Door Window Track Runner 76 ACCO 510A 24 Oct 2020 16:41 #215688
  • Abbuss
Thanks Mate thats beaut I''ll check that
Steering Column Bush 76 ACCO 510A Wanted 24 Oct 2020 16:50 #215689
  • Abbuss
Thanks Jarrod, thats great.I shall pursue that
Steering Column Bush 76 ACCO 510A Wanted 24 Oct 2020 17:55 #215690
  • 180wannabe
  • 180wannabe's Avatar
  • Thank you received: 69
I'm afraid i don't have a parts book for the 510, but all the larger (1610-2152) A series ACCO trucks use -
upper bearing 176 799 R91
lower bearing 864 144 R91
I realise this is not a definitive answer for you, but hope it helps.
Door Window Track Runner 76 ACCO 510A 24 Oct 2020 20:55 #215693
  • mammoth
  • mammoth's Avatar
  • Thank you received: 167
Bailey channel is what it is usually called. Can be either flexible to follow contour of window opening or reinforced with metal and rigid. Best to get the old one out as a sample to match as there are 100's of variations. Let us know where you are located and we can direct to a local supplier.
The following user(s) said Thank You: cobbadog, Abbuss
Steering Column Bush 76 ACCO 510A Wanted 25 Oct 2020 11:12 #215701
  • Abbuss
Thanks 180wannabe at least you guys have got me going in the right direction.It is a bearing not a bush. I think I will pull it out and go from there.Thanks again Abbuss
Steering Column Bush 76 ACCO 510A Wanted 25 Oct 2020 13:27 #215703
  • 180wannabe
Abbuss, if you want to PM me your email address, i can email you the exploded view of the steering column from the parts book.
Brett.
  • Page:
  • 1
  • 2
