Diamond Reo cab over
5 years 2 months ago #218458 by Swishy
Replied by Swishy on topic 1/4 inch air brake hose.
M80
flik me your email addressn eye'll try n send my long winded info
me iz @
beamish(at)beamish.biz
5 years 2 months ago - 5 years 2 months ago #218459 by Tambox
Replied by Tambox on topic 1/4 inch air brake hose.
No prob, send to gj322mail at gmail.com
Thanks Greg
Last edit: 5 years 2 months ago by IHScout. Reason: Edited email address so it isn't identifiable to web crawling spambots.
5 years 2 months ago #218460 by Sarge
Replied by Sarge on topic 1/4 inch air brake hose.
Tambox, I think you are over thinking roadworthy inspections, the inspection people are not design and quality engineers, some things they can only visually inspect for leaks, wear distortion, damage. Etc.... unless there is some common knowlegde trade giveaway like colour coding or ( i am guessing) copper used for brake lines, then they can only accept what they see.
Good luck.
Sarge B)
5 years 2 months ago #218461 by Swishy
EMail now sent to TamBox
5 years 2 months ago #218462 by Tambox
After all these questions, I did wonder how RWC inspectors worked it out.
After all the variable options.
I have built up many cars/ motorcyvles/ trailers for RWC, just wondered if there was any black and white definitions for something that weighs 4 times as much.
Not worried about it, just inquisitive, its a new world to me.
Now copper is an interesting idea, good burst pressure, would look fantastic polished and sealed.
But we all know copper and vibrations/ movemt don't work.
This conversation is great.
5 years 2 months ago #218464 by mammoth
Replied by mammoth on topic 1/4 inch air brake hose.
Pure copper was often used in hydraulic lines but is now banned, bundy tube is fine. Copper remains good for steam engines which typically run at 140psi and more.
NHVR has published a guide for heavy vehicle inspections.
5 years 2 months ago #218775 by Tambox
Replied by Tambox on topic Diamond reo wiring
Thanks to all for the help so far.
Have got it drivable, now trying to sort out the wiring problems.
10km test drive tonight, with some new air valves and hoses.
Replaced/repaired starter relay wiring, no jumper lead to start any more, just press start button :-)
Most of the wires are numbered at connection points, it seems 2 digit number for earth and 3 digit for others.
Any advise on fault finding this style of wiring would be appreciated.
Better still, anyone have any idea how to get OEM wiring diagram.
It has been maintained by a dozer driver.
5 years 2 months ago - 5 years 2 months ago #218779 by hayseed
Replied by hayseed on topic Diamond Reo COE
G'day Tambox. I've Merged all of your different threads together & moved It into the Restoration Section.
It will give you a single Thread to be able to reference All your Progress to on the Truck..
Last edit: 5 years 2 months ago by hayseed. Reason: typo
5 years 2 months ago #218786 by Swishy
Replied by Swishy on topic Diamond Reo cab over
TamBox
gudday m8
trackin down wires sometimes disconnect battery then put a 12v battery wire on the problem wire n track back to where its alive .... negative to earth n Positive to the culprik wire a reliable probe light should help U get it dun
think n most truck makers dun like maken new wire n diagrams for each model of truck etc they may just use there normal numbered wiring then with each model V: they just add more wires n numbers
May B this White truck diagram may help ..... or other wize just bin it
5 years 2 months ago #218788 by 77louie400
Replied by 77louie400 on topic Diamond Reo cab over
Tambox there will be 2 wiring systems in most trucks that age, the one that came with the truck and the one that every driver that's been in it has added when something did not work, for what ever reason, when I got my Louie I remove almost a garbage bin full of wires from behind the dash and under the bonnet, and I am still years later trying to get all the wiring back into the wiring harness and pulling bits of wire out
Time to create page: 0.311 seconds
