Diamond Reo cab over
5 years 3 months ago #218795 by Tambox
Replied by Tambox on topic Diamond Reo cab over
Thanks for that diagram, ill check it and compare.
This is a one owner truck, the owner had no idea about wiring, so it only has original wires, expect for 2 large main power feed wires. The main problem is, when something didn't work, it was repaired by a dozer driver, so there are a lot of cut off wires.
It has no headlight switch, somehow some of the cut off wires should control headlights.
Will investigate further.
5 years 3 months ago #218797 by Swishy
Replied by Swishy on topic Diamond Reo cab over
don't rip all the wires out trace m back and replace/repair where needed
5 years 3 months ago #218799 by hayseed
Replied by hayseed on topic Diamond Reo cab over
No eBay APP ID and/or Cert ID defined in Kunena configurationTambox, I reckon this would be Money Well spent..
5 years 3 months ago - 5 years 3 months ago #218800 by Swishy
Think eye got th@ book
it came with the new White Road Commander 1974-5
Last edit: 5 years 3 months ago by Swishy.
5 years 3 months ago #218805 by Swishy
Yarh
just chekd
I have the same book az above
it has no mention of wiring
5 years 3 months ago - 5 years 3 months ago #218810 by Tambox
Thanks for that, i will work on electrics soon, brakes are a bit more important.
I have screwed the bolts on the diaphragms in, to release the brakes.
I assume to activated the air diaphragms I just undo the screws until they a loose, with no air in the system?
The other problem I have is a PBR low pressure switch with a cracked diaphragm leaking badly. Can I get a diaphragm?
Or any other suggestions?
Last edit: 5 years 3 months ago by IHScout.
5 years 3 months ago - 5 years 3 months ago #219016 by Swishy
RE: I just undo the screws until they a loose
dun put your head in front n firin range
coz th@ spring haz sum bite
tiz a good job 4 the motherinlaw
the pic of the knerld nut on thread may B a air cut off to the shutters on front of radiator
may B to hold shutters fully open or fully closd
RE: PBR low pressure switch
Could B:
Low air pressure lite
Parking brake on
Stop lite switch
5 years 2 months ago #219071 by Tambox
Thanks for that, its an adjustable pressure electrical switch. I think it just operates a light on the dash, which i think has a blown globe, bit more tracing when i have time.
Asked a few truck parts people about it, none have seen anything like it.
There are adjustable air switches for diff lock systems for about $30 on ebay.
Once I work out what it does I might use something like that.
Have a cap to block it atm.
Good old basic machinery works ok without everything working, at you own risk.
Time to create page: 0.318 seconds
