Tri spring sets
5 years 2 months ago #218619 by 77louie400
Replied by 77louie400 on topic Tri spring sets
Swishy wrote: Mrs
M80
Th@ axle packer U talk about could B directly related to the K/Pin height
a perfict height is wen the rocker boxes pivot point R all exactly the same height
Thanks for that Swishy, often wonder why some trailers that sit flat on non tapered beams feel nice even though they sit quite high.
5 years 2 months ago #218622 by Swishy
Replied by Swishy on topic Tri spring sets
Drop the trailer off onto landing legs & run a string line from K/Pin to outer edge of trailer front axle
(in your case if the bearing hub cap runs tru ... compare length from Passenger to driver side
wen U adjust the torque rod to make both sides even on the string line
then U can compare 1st axle to the nex etc
U can get a bit of differation from wen the spring was secured down with the 'U' bolts
az there is a bit of slop where the center bolt head rides on the axle housing
ifn u get my drift
5 years 1 month ago - 5 years 1 month ago #219194 by cro
Replied by cro on topic Tri spring sets
Rocker boxes Seed. Bushes are all in good order, must have been replaced just before it's big rest. Only one rocker needs attention or replacing.
Last edit: 5 years 1 month ago by hayseed.
5 years 1 month ago #219195 by cro
You can see in this next picture where they inserted 2 ft
5 years 1 month ago #219196 by Mrsmackpaul
Replied by Mrsmackpaul on topic Tri spring sets
Swishy wrote: Mrs
M80
I dont think so Swishman, I feel it has to do with chassis camber and on 10'1" spreads, its a long way from the rear axle and chassis is climbing all the way
I am most probably wrong, to my eye the rails climb both ways, from the front of the trailer and the rear as well and sort of meet about towards the middle
5 years 1 month ago #219208 by hayseed
Replied by hayseed on topic Tri spring sets
cro wrote: Rocker boxes Seed. Bushes are all in good order, must have been replaced just before it's big rest. Only one rocker needs attention or replacing.
I'll have a look & get back to you.. may not be until the Weekend though..
The following user(s) said Thank You: cro
Time to create page: 0.365 seconds
