- Thank you received: 22
What's my box? 1962 at4 329 slant 6
2 years 9 months ago #223436
by Boggy
Yes. It appears to be broken.
What's my box? 1962 at4 329 slant 6 was created by Boggy
I am trying to identify the gearbox in my 1962 at4 329 slant 6. Where do I look for numbers? The rear seal is pouring out oil but I need to find out what box I have before I order the seal. I have 2 crushed discs in my back that are making it bloody hard to get underneath. The cousin that I have been getting to do my "ground work" is avoiding me ATM so I guess I will have to get under there myself lol.
2 years 9 months ago #223439
Replied by JOHN.K. on topic What's my box? 1962 at4 329 slant 6
Which rear seal...engine or gearbox?.....the box wll be a New Process 4 sp ,and there are two diffenet kinds in Dodges .....one with a long rear extension like a car,and one thats just flat across the back,with a couple of bearing housings.......IMHO,its unlikely a gearbox will leak at the shaft seal,unless its overfilled to the top,or sometimes they get full of water ,that floats the oil out.(from pressure cleaning).
2 years 9 months ago #223443
Replied by cobbadog on topic What's my box? 1962 at4 329 slant 6
Get a hold of a pair of ramps and back it up the ramps. This runs the oil away from the rear seal and then spray with carby clean around the seal and have a look for the number on the sea. If not found then drop the tailshaft and pull the seal out and put it on the bench at a bearing shop, he will match it in minutes. Look closely at the spigot/yoke where it goes into the gearbox to make sure it is smooth and no grooves or ridges. Once that is good then put it back together. IF the surface for the seal is damaged then buy a speedi-sleeve to fix that.
2 years 9 months ago #223445
by V8Ian
Replied by V8Ian on topic What's my box? 1962 at4 329 slant 6
Thanks Cobba, saved me a bit of typing.
I also agree with John, if oil is leaking from the rear seal, the box is overfull.
2 years 9 months ago #223446
I think its the engine rear seal he s got a problem with.
2 years 9 months ago #223454
Replied by Dave_64 on topic What's my box? 1962 at4 329 slant 6
Tt'As John K said, it will be the New Process, early ones around your era could be the NP420 which had synchro on 3rd thand 4th only, if it is the later and much more common, will be the NP435 which had synchro on 2nd 3rd and 4th. Both had very similar ratios, 1st being non synchro in both are are around the 6.68:1 ratio. Dave
2 years 9 months ago #223462
Hopefully it will be disclosed, gearox or rear engine oil seal.
2 years 9 months ago #223467
Replied by Swishy on topic What's my box? 1962 at4 329 slant 6
Wots rong with compare n the color of the oil
Engine oil will B near on black
CogBox oil could B dark brown
2 years 9 months ago #223472
by wee-allis
Replied by wee-allis on topic What's my box? 1962 at4 329 slant 6
Just asking, but if it was the engine rear main seal leaking, what difference does the type of box make? "Please explain". Sorry Pauline.
Steve.
Steve.
2 years 9 months ago - 2 years 9 months ago #223511
by Boggy
Replied by Boggy on topic What's my box? 1962 at4 329 slant 6
I wanted to know what type of box it was so that I could order the right seal for the box
Last edit: 2 years 9 months ago by Boggy.
Time to create page: 0.456 seconds
