- Thank you received: 3
Eaton 2 speed selector
- RedbullC60
1 year 9 months ago #237619
by RedbullC60
Eaton 2 speed selector was created by RedbullC60
1 year 9 months ago - 1 year 9 months ago #237620
Replied by Lang on topic Eaton 2 speed selector
No eBay APP ID and/or Cert ID defined in Kunena configurationAbout 6 years ago I got a rebuild kit through Truckline for my Commer. It was almost the entire internals but more importantly was only about $100. Included full monkey on a stick, actuator fingers, bearings seals nuts and bolts. Most importantly it included the electric switch and contacts.
I am sure a bit of hunting could find a kit as I believe they were a pretty common parts department holding back in the day. You might have to go to UK but only a couple of weeks wait.
If you can clean the monkey etc up here is the switch in USA but can be found in Australia - note the cheap price.
Last edit: 1 year 9 months ago by Lang.
The following user(s) said Thank You: RedbullC60
1 year 9 months ago - 1 year 9 months ago #237621
Replied by jon_d on topic Eaton 2 speed selector
No eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationNo eBay APP ID and/or Cert ID defined in Kunena configurationIt looks like the Ford B2Q selector is the same.
SOme parts listed on ebay from the US. Shipping is always expensive, but may help provide an alternative search.
mpparts.com/part/ford-b2q-4100-b-shift-motor-12v-b2q4100b
Last edit: 1 year 9 months ago by jon_d.
- Thank you received: 4706
1 year 9 months ago - 1 year 9 months ago #237622
Replied by Mrsmackpaul on topic Eaton 2 speed selector
Dunno if your on Facebook or not, there is at least one Facebook group for these C 40, 50 ,60 & 70 trucks
So if you have no luck then perhaps try there
They built these by the 100s of thousands so I would expect it shouldn't be much drama to find something
Last edit: 1 year 9 months ago by Mrsmackpaul.
1 year 9 months ago - 1 year 9 months ago #237624
Replied by hayseed on topic Eaton 2 speed selector
You can buy an Updated/improved shift gadget that does away with that troublesome preloaded Spring setup...!
Supposed to be heaps better, I Can't find any for sale here in Australia.. But here's one in the States,,
www.anythingtruck.com/product/250-113743.html
Last edit: 1 year 9 months ago by hayseed. Reason: typo
- RedbullC60
1 year 9 months ago #237626
by RedbullC60
Replied by RedbullC60 on topic Eaton 2 speed selector
Yeah cheers,
Actually found that the 113572 was what I needed as mine has three mounting bolts. Could be a good way to source a replacement !
Time to create page: 0.456 seconds
