1980 UD help
15 years 10 months ago #23307 by kennymopar2
Replied by kennymopar2 on topic Re: 1980 UD help
i believe so ..they wernt a bad truck for their day
15 years 10 months ago #23308 by PhilD
Replied by PhilD on topic Re: 1980 UD help
Gee thanks for the response !
I'm about to take the tray off and clean everything up and fix the 3 speed diff (the air change has been disconnected) then put it back together for historic rego.
Meanwhile attacking the rust in the cab.
Might put a small beavertail on the tray at the same time.
Trouble is it'll only carry 6 tons on historic rego which is less than half the empty vehicle weight.
Keep you posted.
Want to be in the shed covered in grease and muck - want a Rum ?
15 years 10 months ago #23309 by mammoth
Replied by mammoth on topic Re: 1980 UD help
Does that mean it tares at over 12 tonne?
15 years 10 months ago #23310 by PhilD
Yes Mamoth,
12.5t Tare
22.5t GVM
38t GCM
which means I gotta get a trailer one day !
15 years 10 months ago #23311 by henryox
Replied by henryox on topic Re: 1980 UD help
Hello,
I found Xtroll absolutly hopeless, i sprayed that stuff into a Loui cab until i was swimming, still rusted, best i have found if you dont want to paint or after you paint it was a mixture of fisholene, (which is main compoment of Xtroll and WD40), buggar, a senior moment, ahhh dear, what do you called that rust proofing stuff that sets like grease, Textol, thats it, 70% fish to 30% textol, fish oil breaks down on it's own but it penertrates carrying the textrol with it, just thin it down a bit, linseed oil is good too, i used to coat all my tube type rims with vegie oil, very light or dust band sticks, i used to work in salty areas
Rob
15 years 10 months ago #23312 by PhilD
Thanks henryox,
Sure you don't mean Tectyl ?
Used to use that for new car rustproofing in the 70s but it may be banned now.
It penetrated but then formed a skin of it's own over itself so even years later it was moist below that skin.
Horrible for one's own skin when putting it on though.
Anyhow let's hope my rust is not too bad.
Worst case is I have to remove the windscreen to get at it.
Hopefully will lift the tray off it next week and can then get it in the shed to work on the rust in the dry.
15 years 9 months ago #23313 by big kev
Replied by big kev on topic Re: 1980 UD help
hey guys i done a ck40 love driveing her 2 this day i stiil dont no what the turbo done
15 years 9 months ago #23314 by kennymopar2
mite be best to take the turbo off & use it as a hairdryer?
some of the early turbos didnt run much boost ..
15 years 9 months ago #23315 by PhilD
Well can't say much about the turbo either.
Seems to work but as yet I haven't even got round to finding out how to raise the cab so there's lots to do yet.
However I did notice today it's charging at 36V which is quite a bit too high so must have some sort of adjustable regulator. Must look ....
15 years 9 months ago - 15 years 9 months ago #23316 by kennymopar2
maybe the batteries r just a bit low . . & the alternator is playing "catchup" much rust in the old girl ?
Last edit: 15 years 9 months ago by kennymopar2.
Time to create page: 0.224 seconds
