1960 Morris WE three tonner. Stopping oil leaking on start up.
7 months 3 weeks ago #252376 by cobbadog
For future tests on the oil leak I would mark both cannister n housing where the oil leaks from. Then next fitments rotate cannister to opposite side n check the result. If it leaks from the mark on the cannister again there is an issue with, maybe tiny split. If leaks from same place on housing look closer at it.
7 months 3 weeks ago #252403 by Morris
Thanks Swishy and jon_d,
I do not appear to have MS word and do not know which other things are word processor files.
I have tried (three times) typing something into emails but cannot get it to Control V and control C into the forum. I do not know what else to try.
Good idea Cobbadog, I will try that when the weather warms up a little and my health stabilises.
7 months 3 weeks ago #252406 by 180wannabe
Just a thought, is the filter element too long?  Maybe after 60 odd years, and decrease in demand, the filter supplier has decided a "one size fits all", even if it doesn't quite fit.
Probably very unlikely, but it was just a thought i had.
Brett.
7 months 3 weeks ago #252407 by Swishy
Yup
John-D had it
forgot about email
Morrie
type anything in an email then hit X to get rid of th@ email u jist typed
then open email and clik on DRAFT
your words should appear
then swipe all the words (normally white writting on a blu background)
CTRL C ....... (C for Copy) this  copies the highlighted text into memory
on 4m Message area clik  where U want the text appear
click CTRL  V  ....... (V for paste)
svgheli.com/cdn/shop/files/Ctrl-C-Ctrl-V...200.jpg?v=1684401825
any problems jist holla
7 months 3 weeks ago #252408 by Morris
Wow, my third test try worked!  Now all I have to do is type an actual message.
As they say "Watch this space"
7 months 3 weeks ago #252410 by Morris
Thankx 180wannabe and jon-d
Thankx for the offer for more help Swishy.
I think (hope) I have got the forum stuff sorted out now.  The oil filter problem may go away with a lot of luck as well.
The following user(s) said Thank You: 180wannabe, wee-allis
7 months 3 weeks ago #252439 by Morris
EUREKA,
I believe I have stopped the leak!!
I bought a new filter for about $40 because Ryco will not sell the gaskets separately.
My engineer mate fitted the larger of the two supplied gaskets on the bench and checked the housing  very carefully for fit. He fitted the housing without the cartridge and it was OK.  He fitted the filter cartridge and when I started the engine IT DID NOT LEAK.
All I can think of is that incorrect gaskets were supplied with the first filter I bought!
Thank you everybody who offered suggestions, most of which I tried.
The following user(s) said Thank You: 180wannabe, cobbadog, jon_d, Mrsmackpaul, PaulFH, grandad, V8Ian, wee-allis, PDU
7 months 3 weeks ago #252449 by Mrsmackpaul
Winner winner chicken dinner
Good result
The following user(s) said Thank You: 180wannabe, cobbadog, Morris
Time to create page: 0.474 seconds
