1947 2-ton dodge truck built by T. and J. Richards and Sons.
3 years 1 month ago #243937 by Inter-Action
With the greatest respect. I 'm not sure i would use that frame of water pipe to lift out truck engines. Just my thoughts. Dave.
3 years 1 month ago #243938 by V8Ian
Here is Part 2 of the engine rebuild.
Love the assorted sizes of Yanky hammers. :unsure: ;)
The following user(s) said Thank You: HalfaDodgeTruckMan
3 years 3 weeks ago - 3 years 1 week ago #244583 by HalfaDodgeTruckMan
good news
I found out the dodge has a mid-type frame for a 1/2 ton truck.
however, it has 2-ton suspension.
and the frame hasn't been altered ether.
Also, I found out I'm wrong on it being a WH, it is a WF-32 160' wheel base.
Last edit: 3 years 1 week ago by HalfaDodgeTruckMan.
2 years 11 months ago #245075 by HalfaDodgeTruckMan
Hey, did you guys know that I have a Youtube channel called Mr Model Railways? no?
A video on the dodge for you all.
2 years 10 months ago - 2 years 10 months ago #246083 by HalfaDodgeTruckMan
List of parts needed:
ENGINE GASKET SET – Andy Bernbaum Auto Parts (oldmoparts.com)
C-513 - Thermostat (228ci, 236ci, 251ci, 268ci) - DCM Classics, LLC
E-110 Manifold bolt Kit - DCM Classics, LLC
E-111 - Oil breather cap - DCM Classics, LLC
E-112 - Freeze plug set - DCM Classics, LLC
E-120 - Decal set - DCM Classics, LLC
CARBURETOR REBUILD KIT – Andy Bernbaum Auto Parts (oldmoparts.com)
DOOR HINGE PIN – Andy Bernbaum Auto Parts (oldmoparts.com)
FAN BELT – Andy Bernbaum Auto Parts (oldmoparts.com)
FREEZE PLUG SET – Andy Bernbaum Auto Parts (oldmoparts.com)
Fuel Filter, Original Glass Style Bowl – Andy Bernbaum Auto Parts (oldmoparts.com)
FUEL PUMP – Andy Bernbaum Auto Parts (oldmoparts.com)
Fuel Gauge, Dash – Andy Bernbaum Auto Parts (oldmoparts.com)
Fuel Tank, 1939-1947 Truck! – Andy Bernbaum Auto Parts (oldmoparts.com)
Fuel tank sending Unit, Truck – Andy Bernbaum Auto Parts (oldmoparts.com)
HEAD BOLTS – Andy Bernbaum Auto Parts (oldmoparts.com)
MANIFOLD HARDWARE KIT – Andy Bernbaum Auto Parts (oldmoparts.com)
Spark Plug “Ever-Dry” Accessory Kit – Andy Bernbaum Auto Parts (oldmoparts.com)
SPARK PLUG WIRE SET – Andy Bernbaum Auto Parts (oldmoparts.com)
Spark Plugs – Andy Bernbaum Auto Parts (oldmoparts.com)
Starter Motor Switch – Andy Bernbaum Auto Parts (oldmoparts.com)
Tune Up Kit*** – Andy Bernbaum Auto Parts (oldmoparts.com)
VOLTAGE REGULATOR – Andy Bernbaum Auto Parts (oldmoparts.com)
LE-733 Turn signal switch - DCM Classics, LLC
B-183 Hood Ornament 41-47 - DCM Classics, LLC
B-504-Kit Cab Mounting Bolts and Springs 39-47 (Steel) - DCM Classics, LLC
B-524-LPB Licence Plate Bracket - DCM Classics, LLC
C-366 - Water pump (1 1/2 - 2 1/2 Ton) - DCM Classics, LLC
C-500 Thermostat Housing - DCM Classics, LLC
C-539 - Radiator Cap - DCM Classics, LLC
E-540 - Engine Crank Handle - DCM Classics, LLC
E-578 Head bolt set - DCM Classics, LLC
I-188 - Dash knob & Cable kit - DCM Classics, LLC
I-211 - Fire wall pad (original style) - DCM Classics, LLC
I-364 - Firewall pad (ABS) - DCM Classics, LLC
LE-104 - Complete wiring harness - DCM Classics, LLC
LE-164 - Headlight assembly (Specify 6 volt or 12 volt) - DCM Classics, LLC
LE-557 - Coil - 12 Volt - DCM Classics, LLC
LE-604 SET - Complete Cowl Lamp Set - DCM Classics, LLC
Bits and bobs needed:
New doors + hinges and nuts and bolts
Back seal and window for rear window
Nuts and bolts for everything.
new hood hinge or new hood altogether
instruments, dials, gauges and switches needed.
My parts list for now, if you have any of these things it would be nice; thank you.
Last edit: 2 years 10 months ago by HalfaDodgeTruckMan.
2 years 10 months ago - 2 years 10 months ago #246085 by HalfaDodgeTruckMan
2 years 10 months ago #246086 by HalfaDodgeTruckMan
2 years 10 months ago #246087 by HalfaDodgeTruckMan
2 years 10 months ago #246088 by HalfaDodgeTruckMan
2 years 10 months ago #246089 by HalfaDodgeTruckMan
