torque setting on old head bolts?
6 months 2 weeks ago - 6 months 2 weeks ago #258405
Replied by Lang on topic torque setting on old head bolts?
I think Paul is right. The main thing is evenly set right across.
My 1915 Willys Overland gave the head torque as "A firm pull on a 6 inch wrench evenly applied to all bolts"
I just looked at a Studebaker 6x6 manual and this gave the head torque for the JXD engine 55-60 ft/lb
Last edit: 6 months 2 weeks ago by Lang.
The following user(s) said Thank You: PaulFH, Fighting Rust
6 months 2 weeks ago - 6 months 2 weeks ago #258407
I have absolutely no idea from all the authorities here are a few for the JXB. The light 42ft;lb suggestion seems to apply to the 1920's OX engine.
Looks like the JXB needs a serious swing on the wrench. Seems a hell of a lot to me so keep looking.
The specific cylinder head bolt torque for a Hercules JXB engine is 85-92 ft-lbs. A two-step tightening sequence is recommended, first to 60 ft-lbs and then a final tightening angle of 270 degrees.
Detailed Explanation:
1. Torque Specification:
The final torque for the Hercules JXB cylinder head bolts should be 85-92 ft-lbs.
2. Tightening Sequence:
A two-step tightening process is recommended. First, tighten all bolts to 60 ft-lbs.
3. Angle Tightening:
Then, starting from bolt #1 and following a specific sequence (which may be found in a Hercules service manual), tighten each bolt by an additional 90 degrees, repeating this process until a total of 270 degrees of rotation has been achieved from the initial 60 ft-lb torque setting.
4. Final Torque:
The total amount of rotation on each cap screw should not exceed 270 +/- 5 degrees after the initial 60 ft-lb setting.
5. Importance of Sequence:
The manufacturer's recommended tightening sequence should be followed to ensure even clamping force on the cylinder head and prevent warping or leaks.
6. Retorque:
After the engine has been run and brought to normal operating temperature, a final retightening of the cylinder head bolts is recommended.
Just contact this mob and instantaneously get your full manual on line.
4. Final Torque:
6. Retorque:
- Thank you received: 2785
6 months 2 weeks ago - 6 months 2 weeks ago #258409
by Fighting Rust
Replied by Fighting Rust on topic torque setting on old head bolts?
Those modern style torque wrenches ( typically made in Asia and sold in many auto parts stores ) that you set by rotating a sleeve to line up the marks - they need to be calibrated regularly in order to perform a accurate job.
www.wikihow.com/Calibrate-a-Torque-Wrench
The old Warren & Brown ( repco ) torque wrenches are reliable, and they stay accurate for many years. Many apprentice tool makers made a torque wrench as part of their training course.
Last edit: 6 months 2 weeks ago by Fighting Rust.
6 months 2 weeks ago #258412
by Fighting Rust
It is possible to reuse the copper sheathed head gaskets, I've done it without any problems. It's a good idea to coat them ( old or new gaskets ) with Hylomar , the spray on stuff is excellent.
I've had problems with damaged threads in blocks after removing head studs. Sometimes as you remove stuck studs ( using heat ) , the corrosion/rust on the studs can enlarge the thread form in the block, this damaged thread then may require helicoils .
6 months 2 weeks ago #258413
Replied by cobbadog on topic torque setting on old head bolts?
I use that copper spray on all head gaskets now with great results. Have to lift the head on the David Brown when we get back home. I feel that there are one or 2 sticking valves.
6 months 2 weeks ago #258415
Replied by JOHN.K. on topic torque setting on old head bolts?
Angles wernt invented when these motors were common.......I had a heap of trouble with the flathead Continentals in Hyster forklifts leaking water through corroded passages .......hit on the idea of using silastic on the head gasket .......no more leaks
Time to create page: 0.281 seconds
