When a another Bedford restoration is barely enough
3 months 3 weeks ago - 3 months 3 weeks ago #259407 by MichaelL
Hi All
I retired about two years ago and been on the lookout for a project, a couple of weeks ago i purchased a Bedford J1
One previous owner and must have been kept in a shed for most of it’s life
Hardly any body rust ie surface rust issue. It’s had a respray around 15 years ago and looks very good for it’s age, however I’m  pretty sure it was originally white
The fact that the body is so good is a blessing for as while I’m no mechanic I’m certainly not a panel beater / or welder of note
Here are some specs:
Chassis: Bedford J1s
GVM: 2 ton 18 CWT
214 Cubic inch engine
Engine number: J1232163555
Cab: 22503
Trim: 501-1007
Paint: 568-9858
And another plate with simply: A008005
Anyways, slow and steady wins the race
I hope that I can tax peoples brains on this forum as I go, especially tracking down parts
Needs immediate attention to Brakes, Diff pinion seal, Probably Rear main cranckshaft seal and radiator is tin rouble
Engine runs nicley, but fuel system could do with a refreash
Anyways, if soemone could note the original colour for me that would be great, it’s a white of some description
cheers
Michael
Ps: attempted to add a pic, not sure if this will work
Last edit: 3 months 3 weeks ago by MichaelL.
The following user(s) said Thank You: 180wannabe, cobbadog, eerfree, PaulFH, Southbound, wee-allis, oliver1950
3 months 3 weeks ago #259409 by Mrsmackpaul
Welcome to the forum
Picture worked just fine
Sounds like a good base for some fun and adventure
The following user(s) said Thank You: 180wannabe, cobbadog, PaulFH, wee-allis, MichaelL
3 months 3 weeks ago #259410 by asw120
9858 - Coast Ivory.
3 months 3 weeks ago #259411 by MichaelL
Thank you, cheers
3 months 2 weeks ago #259413 by jon_d
Nice and welcome.
Typical Bedford but....    Front brakes faded and smoking even when parked in the paddock.
I sleeved mine.
3 months 2 weeks ago #259420 by mammoth
Electric fuel pump (from ebay) will save a lot of grief.
The following user(s) said Thank You: cobbadog, PaulFH, Southbound, MichaelL
3 months 2 weeks ago #259524 by Colin HD
Good to see another Bedford being given a new lease of life.
Can never be too many.
The following user(s) said Thank You: Mrsmackpaul, PaulFH, wee-allis, MichaelL
2 months 3 days ago #260272 by MichaelL
Hi All
I bought the truck knowing that the brakes were locked up, vehicle will move but moves jerkily (if that’s a word)
Its my understanding that the truck is fitted with Clayton Dewandre brakes, please correct me if I'm wrong
So I have include a pic of a PBR Vacuum Gauge located on the steering column, I don’t know if this is standard, I have included some pics of the Gauge showing around 13-14 Lb while engine is running and a pic from a different angle
I have included a pic of the tow bar, as located here appears two, I’m thinking air lines for what I can only guess is for a trailer fitted with air brakes, correct me if I'm wrong
Any tips, explanations or links where I could follow this up would be appreciated
Kind regards
Michael
2 months 3 days ago #260274 by 180wannabe
Hi Michael,
I think the gauge in your photo is actually measuring vacuum in "inches of mercury", rather than air pressure in PSI.  I am pretty sure some of those PBR hand controls did have a gauge fitted on top as standard, although i have not seen one quite that modern looking.
And as for the connections at the rear, yes they are for trailer brakes, but again they are vacuum lines, not air.
Unless there is an air compressor belt driven off the front of your engine, then i am sure your truck does not have "air", only vacuum.
Brett.
The following user(s) said Thank You: cobbadog, wee-allis
2 months 3 days ago #260275 by 180wannabe
There is a thread on this forum called "Vacuum trailer brakes" started by "projectinter", but i am afraid i don't know how to link you to it, sorry.  My best suggestion would be to google "hcvc vacuum trailer brakes".
I don't have a lot of luck with the forum's search feature, i find google finds things a lot quicker and easier.
Brett.
The following user(s) said Thank You: cobbadog, PaulFH, roKWiz, wee-allis
Time to create page: 0.369 seconds
