White 9000 Resto
15 years 2 months ago #40489
by Gearbox
Replied by Gearbox on topic Re: White 9000 Resto
Does make you wonder why the wiring has to be so bad on most old trucks things get put in things get pulled out but why leave the fire hazard to burn the old girls down will be a great classic when sorted
15 years 2 months ago #40490
Replied by geoffb on topic Re: White 9000 Resto
Cover actually fits and floor plate
Just got to get some good insulation to place under and fasten down.
15 years 2 months ago - 15 years 2 months ago #40491
Need some help to get Tacho cable manufacture eg types of ends for both
Also the same for speedo. I would think that there is some sort of standard name for these types of ends and wether they be keyed or square drive.
Geoffb
Geoffb
Last edit: 15 years 2 months ago by geoffb.
15 years 2 months ago #40492
by Chocs
Replied by Chocs on topic Re: White 9000 Resto
Hi Geoff
i used Guageworks here in Geelong
blokes name is Luke: 52779296
I had to sample the ends though Geoff.
Its a nuisance pulling the bits out but you will get it right first time..
Sorry i don't have any more 'correct' info..
i do have a little tin full of all different ends and adapters though. Even the sline and transtar are different, although both roadys..
regards
chocs
regards
chocs
15 years 2 months ago #40493
Unfortunatly I have no samples at all as the old girl had none of these cables at all
Geoffb
Geoffb
15 years 2 months ago #40494
by Chocs
sorry Geoff...
i had to take the guages and 'other' ends in
chocs
chocs
15 years 2 months ago #40495
by Tacho
Replied by Tacho on topic Re: White 9000 Resto
G'day Geoff, I have just been through the cable exercise with my D Reo. I took the tachograph in for a check and clean, removed the tacho and speedo drive end brackets (only a couple of screws) and used a piece of half inch dripper hose to work out the length of cable needed. When I got it back from Guage Works Adelaide it all fitted and worked like it should. Guess I am old enough to have learned that it is better to "cover the bases", especially as I am an hour and a half out of town. Cheers and hope to see you at the White muster.
Geoff
Geoff
15 years 2 months ago #40496
Replied by bigcam on topic Re: White 9000 Resto
Geoff, I'll have a look when I'm back at work, I'm pretty sure I've got a tacho cable. The ends are the same on my Road Boss for Tacho and Speedo, and the Reo as well, so I should be able to at least get you the sizes for the ends if the cable isn't there. Flexidrive charged me about $80 for a new speedo cable for the Reo, and the ratio box was about $160.
15 years 2 months ago #40497
Well after the initial grieve the power steering leak now appears to be fixed grand sum $10 plus time . But remembering this is just temporary repairs to get the beast going. Without CHOC"s getting over glorified about GMs and oil fuming from air box drains what is excessive. As the manual just refers to making sure that they breath
Geoffb
Geoffb
15 years 2 months ago #40498
by Chocs
gday geoff...
from memory they run at about 7? psi in the airboxes..
What is excessive? heaps more oil than air coming out...
Give the ol girl a good run when you a chance..
it should clean up to a fair degree, unless she's getting a bit puffed.. if she's dripping more than you are happy with..mount a tin underneath with a couple of hoses running loosly into the top of it, make sure they can't get blocked..that'll stop it makin a mess on the new house..
Is that the info you were after?
regards
chocs
regards
chocs
Time to create page: 0.315 seconds
