White 9000 Resto
15 years 4 months ago #40499 by geoffb
Replied by geoffb on topic Re: White 9000 Resto
Just keeping up to date
This was removed from the chasis rails today and finally all the rear lights actually work every time
The only edition to the workshop/ truckport was the following
There is no sale but everything has a price but thought would be good for sport watching. Just need a step top box so that I can be political correct and watch things that need translating (Chocs the excess external silastic has been removed)
Geoffb
15 years 4 months ago #40500 by Chocs
Replied by Chocs on topic Re: White 9000 Resto
Ya have done well geoff!
did ya save me the offcuts for a rocket cover gasket! ;D
I ended up with a packed 4 gallon drum of wire out of that 4070!
surprisingly, most everything still worked with it out!
chocs 8-)
15 years 4 months ago #40501 by melonreo
Replied by melonreo on topic Re: White 9000 Resto
choc's
i did not know that you worked for N.A.S.A what are you doing play with rockets ;D
15 years 4 months ago #40502 by ianoz
Replied by ianoz on topic Re: White 9000 Resto
Melon , He can't answer that . Rocket sientists are sworn to secercy :-X :-X ;) :). Ian .
15 years 4 months ago #40503 by
What chocs was actually saying, in a subtle manner .. is that all Cummins engines, go like rockets .. as compared to some other brands .. that go like snails on Valium .. ;D ;D ;D
15 years 4 months ago #40504 by ianoz
Chocs , looks like another one to report to detension ;). Even up the class a bit . ;D. Ian .
15 years 4 months ago #40505 by geoffb
Well to the new engine cover applied urethane (not salastic for your benefit chocs) and fitted new insulation with out Govt grant Modern technology should make more comfortable Also new floor plate to fill in behind cover
Keeping in mind this is permeate / temporary fixes till we start full tear down (If this bores anyone please tell someone else)
Geoffb
15 years 4 months ago #40506 by Daninmky
Replied by Daninmky on topic Re: White 9000 Resto
Geoffb
lol ;D
2 Blondes Walked into a Building.......neither of them seen it.....BOOM  BOOM!!!&&A blo
15 years 4 months ago #40507 by Swishy
Replied by Swishy on topic Re: White 9000 Resto
JeffMan
in a word
B O R I N G
U should B out hoon n
putn the pedal to the metal
get out n make a mile
put all the screemer power to the ground
n have n fun
any hints n tips
on the insulation
the only thing we learnt (the hard way)
Iz:
When U put the black urethane as a seal
we apply a smidge of oil on one surface n the other surface apply the ureathane
screw down firm (but dont over do it) best to leave a thikness of 5 mill
then with soapy water drag u're finger round the exposed surface to give it a good finish
24 hours n afew cans later
remove the newly sealed doodadd th@ should freely pull away with the oil under it. by then U should/could/would have a new 5mm gasket seal
remove oil n screw it down again
It aint perfect
butHooIz
Keep them pix cummin
n U aint gunna bore uz nun
[ch9787]
15 years 4 months ago #40508 by
Nice work there Geoff
Time to create page: 0.314 seconds
