- Thank you received: 661
White 9000 Resto
15 years 1 month ago - 15 years 1 month ago #40509
Geoff, I trust that insulation you used is the variety that doesn't start fires! ..
.. and that the Govt Inspectors have been around, to see that it was installed properly, to make sure the Govts money wasn't wasted ..
Cheers - Ron.
Cheers - Ron.
15 years 1 month ago #40510
Replied by Sarge on topic Re: White 9000 Resto
Geof. Enquiring minds need to know.... whats the insulation, I assume its not just bright polished tin foil????
/me
/me
15 years 1 month ago #40511
Replied by geoffb on topic Re: White 9000 Resto
I may be cheap but I don't kiss on the first date All jokes aside it is by the add heat shield up to 750dec came in sheet form 900 x 1500 (Insulation has nothing to do with one P Garrett) hopefully does the job
Geoffb
Geoffb
15 years 1 month ago #40512
Replied by bigcam on topic Re: White 9000 Resto
Geoff, if it's like my Road Boss, that insulation won't make much difference. Mine is a tropical cab, cold in winter, but yet hot in summer.
15 years 1 month ago #40513
Juan Trak
RE:I trust that insulation you used is the variety that doesn't start fires
Most of the house fires were started by electical wires
n Az we orll kno the Geoffman removed a bucket of wire from the beast
so it should/could/would B fire safe
[ch9787]
Replied by Swishy on topic Re: White 9000 Resto
Juan Trak
[ch9787]
15 years 3 weeks ago #40514
Well just a bit of a update
http:
Still requires a couple of braces
Now for the next major is the rear pulled that apart
Did some measure for reference before disassembling and found on side to be 25mm longer than the other interesting concept
15 years 3 weeks ago #40515
G'day Geoff,
It looks like you're making good progress there.
-Stu
-Stu
15 years 3 weeks ago #40516
Giday Geoff, getting a bit done mate, i reckon i pulled a hundred feet of unused wires from the S2
most tandems have a long and a short axle, its the opposite on the front a diff,
Cheers Adam
Cheers Adam
15 years 3 weeks ago #40517
Not sure if I was clear but 25mm longer in wheelbase not track width would like to have seen tyre wear or maybe this was general wear or within tolerance
Geoffb
Geoffb
15 years 2 weeks ago #40518
Well a bit more progress remove old diffs abit easier than excepted
Then down the road
Identity keep as we did not have road closure or flag people or permit for this move so was probably not within work safe parameters
So the old girl sitting there and striped like a brides (Hope that's not reskay) nighty
As for photos I don't real care who uses them The ones I don't want shared will not put on the photo bucket thing
Then down the road
Time to create page: 0.294 seconds
